Question about Verbatim 500GB USB Desktop 500 GB Hard Drive
Verbatim usb500 has stop connecting to my computer,was working fine,disconnected it from the computer..reconnected awhile later and know computer is not reading the external?
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Why does my acer aspire 5315 wifi keep disconnecting and reconnecting?
hello sir.
Reason :-
1.Make sure your acer aspire is in range.
2.cheack is it your wireless disconnecting and reconnecting or is it your internet disconnecting and reconnecting.
3.Are you facing this issue with any other machine or is this the only one.
If this is the only computer in which your wifi connection is dropping then there is issue with wireless connectivity.
solution:-
1.Turn of your router and modem and then check the wireless connectivity.
If issue still persist then:-
2.Create a new network name and wireless security key and then connect to it:- Now check the wireless stability whether is it still disconnecting an reconnecting or is it stable now.
If issue still persist then bright your laptop close to router and then check wifi disconnecting any more or not if not then change the channel to 1 or 11 from your wireless router page.
Let me know if this worked for you or not.
If worked then please rate my solution.
May 25, 2012 | Acer Aspire 5315 Notebook
I have a verbatim external hard drive, model usb500 and my computer does not recognize it. I have it plugged into a working usb port and the blue light on the drive is on, but my computer isn't...
You need to assign a drive letter for it to show up in Windows.
Right click on My Computer, click Properties. Then go to disc management, and right click on your external hard drive, and click Assign Drive Letter, and choose a letter and it will show up in My Computer.
May 08, 2011 | Computers & Internet
Usb500 with windows7, i plug in and windows recognizes the drive but no icon in my computer.
you may have to go to disk management and format the drive first. go to start > right-click on computer > select manage. this will open computer management. go to disk management on the left pane. you should see the verbatim drive as unallocated space, right-click on it and format the drive as NTFS quick format.
May 03, 2011 | Verbatim Computers & Internet
Hey... So i have a verbatim wireless optical mouse Model # 96781. I used it for about a month then it crapped out on me. the lights are fine and the computers i try it on recgonize it. It just wont...
I have this mouse. It automatically disconnects, probably to save battery. A single click on the left mouse button will reconnect.
It sounds like you have a bad receiver (usb) or transmitter (mouse). I would try to get a replacement.
Apr 22, 2011 | Computers & Internet
What plug can i substitute for a verbatim USB500 portable hard drive? I only need the wall plug.
I believe you also need a dc transformer that has a wall plug on one end and the plug for your USB hub on the other.
Mar 19, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
How to use verbatim model # usb500
Plug it in one of the usb ports of your computer. Check if the external hard drive has a power button.
Normally, something will pop up on the screen asking you to install the software that came with it.
Follow the instructions and you may now use the external drive as your back up drive.
Jun 08, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
My computer says Verbatim is healthy but will not access
Restart Windows, to clear the table of "device names that are being used". Reconnect the Verbatim.
Mar 17, 2009 | Verbatim External, USB 2.0, 750GB...
Verbatim 500GB USB Desktop 500 GB Hard Drive Logo
1,368 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
