Question about Bose 3·2·1 II System
A terrible hum or buzz in the bass and speakers.
  • roberto242 Sep 09, 2010
    Tried it all and nothing worked. I have another 3.2.1 unit and plugged the powered speaker system to it and it works pefectly, the probem is in main bass unit.
    Tried it and didn't work. I bought two 3.2.1. units, they are new, and I plugged the other systems Bass System and there is no problem. The problem is in the bass unit. HELP.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check that the speaker cables are not damaged and the connections are secure. Also reduce the output level from any external components connected to the unit. Check all the connections for external components. Disconnect any headphones. Unplug the unit from the power socket and mains. Reconnect power and try again. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 09, 2010
  • Rylee Smith
    Rylee Smith Sep 09, 2010
    If everything is fine then the issue is with some component burned inside the unit and you'll have to open it to check what has gone bad.
Humming/buzzing
This is a nice speaker. You could get humming from the wires being crossed they actually do have polarity and better speakers will hum if the wires are crossed. The volume cloud also be too high without input. You also may have some interference with other audio wires or power wires close to the speaker.
Apr 05, 2014 | ElectroVoice . Speaker
Buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
Nov 03, 2011 | Logitech Z-4 Computer Speakers
I have a 96 town and country chrysler. WHile I
I have same problem , But I have to turn on and off radio to get it to work :) Some times you hear nothing on fm and turn to am and its playing ... then the load humming comes about .. drives me up the freaking wall .
Sep 16, 2011 | 1996 Chrysler Town & Country
Loud humming buzz when I turn it on
Failure, likely in the power amp causing overloading of the power supply and dragging one power voltage into the range where the ripple voltage gets to the speaker. This is very ******* the speaker as it gets high DC current and can burn the voice coil. Slight chance that a filter capacitor has failed. In either case repair is needed.
Aug 11, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
Bass speaker buzzing
I've had this problem too multiple times. Usually when it happens, the battery dies soon after, and once I replace the battery, the buzzing goes away. If you are having the same problem as me, try putting a fresh battery in :)
Mar 09, 2010 | Skull Candy Skullcrushers Headset
Buzzing/humming noise that increases as you raise volume. So loud that you can not even watch tv
Hello snow1525,
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 16, 2009 | Televison & Video
Terrible distortion from Sony Dav-x10 2.1 subwoofer
its not broken just turn the cut off frequency to level and the volume of the sub lil bit higher and it should work fine.
Nov 11, 2008 | Sony SA-W305 Subwoofer
Bose 3·2·1 II System Logo
48 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
