Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Posted on Sep 08, 2010
  • MAHEN Jun 24, 2012
    HI JUST WANTED KNOW,MY SHOWER HEAD KEEPS COMING OFF THE PIPE WHEN ITS HOT,ANY SOLUTION....THANKS.
2 Suggested Answers
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
We had both the shower and the Bath tub remodeld and installed new Moen faucets with a single knob that turns right to left to open. All was fine for a couple of days but all of the sudden they startd...
You need to install a new moen cartridge its a single handle posi-temp cartridge you should be able to get 1 for free if you are the original owner by calling 1-800-buy-moen more than likely when soldering in the new valve a little bit of solder broke free into the cartridge or hard water. When the water gets turned off and then turned back on it can break free alot of particles that can get jammed up in these cartridges or any fixture for that matter you will need a cartridge puller to perform this job with ease.
Aug 27, 2011 | Moen & One Handle Tub & Shower Faucet
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
New moen one handle shower faucet drips
sound's like you either have some debris caught up in there, or you might not have your handle on correctly. give that a try .
Jan 23, 2010 | Moen & One Handle Tub & Shower Faucet
Moen fauset # 1225 Shower new cartridge and it still drips.
is it official moen 1225 ? generics can be of poor quality. turn off house water and remove cartridge. Small fingers? Put in valve and feel for debris or turn on whole house again for a few seconds to flush out valve. try another cartridge. Or try this first. take off handle and push in on stem. does drip stop. ? perhaps handle is not on right.
Apr 28, 2009 | Moen Plumbing
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
477 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
