Question about RCA HD61W66 61" Projection HDTV
Picture screen looks as if it is bent from top to bottom... Picture is clear in the center of the screen but blurred on the left side. When looking at the tv guide, words on the left hand side of the screen are out of alignment with red being out of line like you're seeing double. I tried to unplug it for 5 minutes, and it cleared up, but now, several weeks later, the problem has returned and unplugging the tv and will not resolve the issue. When trying to adjust the convergence settings on the menu, it will not let you set anything, because the red and blue pluses are in line.
  • RCA Master
  • 11,800 Answers
The convergence board has failed, a common problem on this tv.  You need this
http://www.tvrepairkits.com/xcart/product.php?productid=24762&cat=3911&page=1
to fix it.
Posted on Sep 08, 2010
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Blurred pictures,displays green,red colors on screen,picture curve at top and bottom of screen
Go to Menu then setup Look For Convergence,If you Do Not see Convergence in the Menu then you have a Blowed Fuse on The deflection Board FL231.
Deflection Board is the Bottom Left hand side board that has (FBT) flyback Transfomer on it.
If you are Not able to repair it yourself ,then you can ship Board to PTS for repair.
1-800-844-7871
Jul 06, 2011 | RCA HD52W56 52" Rear Projection HDTV
I was watching my HCL4715W TV and the picture
It sounds like one of the convergence Ic chips is bad---you will need to locate and replace both of them and look for any damaged parts around them; there usually are two pico fuses in this area, one for each IC. The fuses do not look like glass fuses--they usually are green or orange in color and will have the amperage marked on them and on the top of the circuit board.
Aug 09, 2009 | Samsung HCL4715W 47" Rear Projection...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Black screen, but perfect sound
all you need to do is change the lamp...go to a tv repair man tell them the model/serial no. and the lamp code..you will find that on the left had side of you tv as you are looking at the screen,,,that should do it for you. good luck
Jun 02, 2009 | NEC PlasmaSync 50MP1 50 in. Television
LCD screen is extremely blurred
It is probably not the LCD itself, but an element that is protecting the LCD is bent out of shape.
Jan 16, 2009 | Vivitar ViviCam 5386 Digital Camera
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
RCA HD61W66 61" Projection HDTV Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
