Question about Frigidaire FWSB7800DS Top Load Washer
Water is leaking from the tub. The hose and pump seem to be working properly
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
  • 115 Answers
SOURCE: Washer leaking when filling up tub
i dont know what he is talking about and the leak on that machine I am 99% sure you just need a new pump it leaks out the center of the pump where it goes on the motor shaft just lean it back take off the 2 clamps on the pump slide it off the motor and then take your hoses off it then just reverse it with a new pump
Posted on Jan 01, 2009
  • 125 Answers
SOURCE: water leaking
it could be the boot seal, (rubber piece that joins the tub to the front panel). the boot can get a hole in it or it can pull away from the tub if the clamp loosens. if it is the front of the outer tub that is cracked the manufacture did warranty the tub for ten years prior to 2006. check your owners manual as that is what the company has to honor. they only cover the part not labor, and in the usa only. i hope this helps.
Posted on Apr 25, 2009
jmgldsmth
  • 2005 Answers
SOURCE: leaking tub on whirlpool washer
replace the main (under tub) seal
Posted on May 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 44102 front load washing machine leaks
It appears your Pressure Switch tubing has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
WFL 2066 NOT DRAINING FULLY - NO SPIN
try to dismantle pump and reposition it and clean dirts that have accumulated on it that prevents water to fully drain. best i got
May 20, 2008 | Bosch WFL 2063 Front Load Washer
Tip
The washing machine is leaking all the time?
The possibilities for this problem are mentioned as follows:-- Check the water filling hoses which lets the water inside the washing machine while filling. There are two fill hoses.one for cold water filling or one for hot water filling.if this hoses are worn out or cracked the washer will leak.so both the hoses needs to be checked and replaced. But if the hoses are checked OK then other possibility is the tub seals on the tub.The seal can be seen between the transmission assembly and outer tub assembly of the washing machine. If the tub seal is got loose or worn out it needs to be checked and replaced. But if the tub seals are proper and not worn out then other possibility to check out is the drain pump.Check if the pump is got cracked ,loose or worn out.in case or cracked or worn out it needs replacement but if its loose you can just refit it properly to stop the leaking.But if the pump is not leaking and it looks properly fit then other possibility to check is the outer tub assembly.its made up of plastic and this plastic gets cracked after certain period of time.or if any pointed object/material if remain in the clothes while washing .then due to that pointed object there becomes a hole in the plastic outer tub assembly .This all the possibilities.that has to be checked. This will help.Thanks.
on Mar 18, 2010 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
There is water leaking from the bottom of the washing machine
couple of things to check, one make sure the drain hose is properly attached and no clogging. and also make sure all gakets are in good shape. and not worn out.
Nov 06, 2009 | Washing Machines
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks and spin cycle not working properly
Water leaking from the bottom usually indicates either a bad hose , bad hose connection to the pump or a leaking pump. Also sounds like the machine is not spinning out. Is there water left in the tub at the end of the cycle?
Feb 28, 2008 | Maytag MAV7600 Top Load Washer
Frigidaire FWSB7800DS Top Load Washer Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
