Question about Epson DFX-9000 Matrix Printer
Check print head with pattern print dfx9000 adjustment program
5 Suggested Answers
lenny297
  • 133 Answers
SOURCE: Pixma 130 Head aligment
If no windows appears i think your printer software is corrupted and need to be reinstalled
Posted on Feb 28, 2008
Basti
  • 1447 Answers
SOURCE: dfx9000
Hi-
Have you tried adjusting the platen gap, run a selftest on the unit and if doesnt print/if you are getting a blank page still. you have to adjust platen gap- check the setting as well on the panel try setting it to default.
Posted on Aug 04, 2008
SOURCE: Canon Pixma IP4000 5 ink
I spoke to a company called CRC (Tasktron Limited) who are repair specialists for all kinds of business machines. They can be contacted at 01483 776060 or via www.crc-tasktron.co.uk.
After explaining my problem and the amount of use my printer is subject to, they advised me that the printhead was past its useful life. They offered to send me a relacement (£40) which I received today (next day delivery) and fitted in two minutes. Problem solved.
Posted on Dec 05, 2008
  • 27 Answers
SOURCE: Epson Nozzle check
hi sandysun,
try to deep cleaning at you nozzle from printer software at printer properties..it should help..
if still the same problem...u printhead got problem...try to take out you print head..put in the hot water..becarefull dont wet the chip near the print head
Posted on Jan 08, 2009
Not printing black
Sounds like the print head needs alignment. If an "auto" alignment can't or won't be run, somewhere in the maintenance section of your printer driver software should be an operation for running a print head alignment and doing adjustments to get the printer aligned for clear printing. First you should check the maintenance program for "head cleaning" and run a couple of head cleaning cycles to see if a clogged head is the problem...
Jan 28, 2013 | Office Equipment & Supplies
Error30 dfx9000
check print head built in thermistor and the carrier cable.In Case You Still Having Problem Then Follow Us For On : Epson Printer Support
Dec 16, 2012 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Wrong cartridge error code on canon pixma mp780 printer
Reseating the print head is seldomly needed to be done.Press the Open Button (1) to open the Paper Output Tray (2) Raise the Scanning Unit until it stops. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.The Print Head Holder moves to the middle Open the Inner Cover 1.Open the Inner Cover 2.CAUTION: a. Do not try to manually move or stop the Print Head Holder.b. Do not touch any metal parts.Press the ink tank's tab (1), then remove it from the slot (2) IMPORTANT:Handle ink tanks carefully to avoid staining clothing or the surrounding area. Lift up the lock lever and take out the print head.Again, place the print head back in position and press down the lock lever. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot IMPORTANT:a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.b. If the ink tank is inserted in the wrong slot, perform two head refreshings.Close the Inner Cover 2.Close the Inner Cover 1.Pull the Scanning Unit Lever towards you to close the Scanning Unit.Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.Automatically Aligning The Print Head Position:Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].Press <Menu> epeatedly until [MAINTENANCE] appears.Press left or right arrow to select [AUTO HEAD ALIGN].Press <OK>. The print head position alignment pattern prints.Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete. Manually Aligning The Print Head Position:When automatic alignment does not work well, align the print head position manually.Load A4- or letter-size plain paper in the paper support or cassette.Select the paper source with <Feed Switch> button.Press <Menu> repeatedly until [MAINTENANCE] appears.Use left or right arrow to select [ALIGN PRINT HEAD].Press <OK>. A horizontal pattern is printed.Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.A): Column(0): Select pattern number with most solid image Press <OK>.Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].Press left arrow. A vertical pattern is printed.Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.Press <OK> Repeat steps 12 and 13 to adjust column N.
Oct 09, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Missing some paragraph lines while printing text files on my Epson DFX9000
are you running out of ink? printing at draft quality? head cleaned maybe?Or
Follow Us On For Online Support For Epson Printer Support
Sep 08, 2011 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Auto print head alignment wont work and I need to do a manual alignment. How do I do this for a MP970?
1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette. 2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension. 3. Press the Paper Feed Switch to select the paper source where you have loaded paper. 4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
5. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
6. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
7. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
Mar 01, 2011 | Office Equipment & Supplies
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
May 16, 2010 | Canon MP970 Photo All-In-One InkJet...
The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
White bands on color photo prints
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Dfx9000
Hi-
Aug 04, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
290 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
