Question about Admiral AAV7000A
Admiral washing machine AAV8000 AGW this machine has been exceptional up until today, it fills (seems to over-fill) then stops? it does not complete a cycle and it does not drain, however when the power is turned off and left off for say 10 minutes, flick it back on again and then it drains but does not complete the cycle. i have gone thru all the troubleshooting detail and figure it could be one or two of the following: faulty lid switch impeller on drain any help out there! Robbie
    Top Expert:
  • Admiral Master
  • 77,499 Answers
It sounds like the timer circuit has failed, suggest you replace it and see if that cures the problem
Posted on Sep 08, 2010
My admiral washer will not fill up with water nor will it wash
Hello Melyssa
Have you tried both hot & cold water?
different settings?
stop mid cycle?
need more info
Jun 10, 2015 | Admiral Washing Machines
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
I have an Admiral Heavy Duty Super Capacity 2 speed washer. It works great except that it takes forever to fill (3hrs!). I've taken to filling by hose each cycle. Am in a rental so don't have the...
low water pressure..... stopped up or kinked up water inlet hoses.......stopped up water fauset at machine......stopped water filter,s at machine ,,, or at water valve.......or bad elec water valve at machine
Mar 16, 2011 | Maytag Washing Machines
Wash machine is draining while trying to fill up
Make sure your drain hose only goes into the stand pipe about 4" and secure it. If it goes in too deep a siphon will occur. Also make sure your stand pipe is not too short. It needs to be 18" above the trap or 30" above the floor. If it's less, then siphoning can also occur.
May 19, 2009 | Washing Machines
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Have an Admiral AAV8000 that does not stop
Sounds like you have a mechanical failure and the timer keeps advancing because the cam contact for the timer motor has to be manually shut down. Your timer is part 21001929
Jun 28, 2008 | Admiral AAV7000A
Machine won't stop filling
Sounds like your solinoid valve needs replacing. It cuts the water off when it has reached the right level.
Nov 19, 2006 | Admiral AAV7000A
Admiral AAV7000A Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
