Question about Linksys WRT54G2 Wireless Router
I need to locate my network key to connect wireless on my laptop.
  • 57 Answers
1. open internet explorer or any browser, type 192.168.1.1 on address bar..
2. log in to your router.. leave username box empty, type "admin" for the password..
3. Go to the WIRELESS Tab, then click Wireless Security.. you should see there the wireless netwrok key / passphrase
Posted on Sep 08, 2010
I don't know how to turn on the wireless capability on myself?
What type of computer Desktop or Laptop & Make ???...
If your computer will not connect to a wireless Internet signal, one of the first things to check is whether your computer's wireless switch is turned on.
Many laptop computers have a switch located on the exterior of the computer that controls its ability to connect to wireless networks.
This switch can be accidentally turned off, preventing users from connecting to the Internet.
Determine if your computer's wireless connectivity has been disabled by viewing the network icon in the lower toolbar on your computer's desktop.
When there is a disruption in your computer's Internet connection, the icon will have a red X through it. For further information, go to the computer's Network and Sharing Center where you can troubleshoot connectivity issues and view available wireless networks.
If the computer isn't recognizing any wireless connections (and you're sure that there are wireless signals in your area), the likely problem is that the wireless switch is turned off.
Locate the wireless switch on your computer.
It may be located on either side of the laptop or along the back or front.
If you aren't sure whether your computer has a wireless switch, check the user guide that came with the unit.
Determine whether the switch is currently in the "On" or "Off" position.
The switch will be clearly labeled.
Push the switch in the direction of the "On" position to ensure that it is turned on.
If the switch was already turned on, see if there is a keyboard combination that will activate your laptop's wireless capability.
The key combination for your laptop will depend on your computer's manufacturer, but will generally involve a combination of the Function, Control or Alt and the F1 to F12 keys.
Check your user manual for your computer's key combination.
Troubleshoot problems finding wireless networks
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
Aug 13, 2013 | Computers & Internet
Tip
How to configure the wireless connection ?
Configuring the Wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
on Jan 22, 2010 | Computers & Internet
Cannot locate wireless networks with Broadcom with my HP mini 2140
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 08, 2013 | Computers & Internet
Wi-fi not working
If you are connecting to someone's wireless network without theie permission then they most likely decided to secure their wireless network.
You can connect to a free wireless network at locations such as the airport, Macdonalds or Starbucks etc. These are ususllly unsecured wireless networks.
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 09, 2012 | Fujitsu Siemens Computers & Internet
My dell vostro A860 cannot connect to wi-fi.am usin windows 7.wat might be the problem?
Wireless Internet has become increasingly popular as a means of connecting to the Internet. Wireless networking allows for users to connect to the Internet without having to physically plug anything into the computer. If you are not able to connect to any wireless Internet connections, it is important to take a few simple troubleshooting steps on your own to understand the cause of the issue and resolve it.
1.Try connecting to multiple wireless networks. The first step in diagnosing a lack of wireless connectivity is to try more than one wireless network. This will give you an idea of whether the problem is with your laptop or just with the single wireless network to which you are trying to connect. Take your Dell D600 to one or more free public wifi hotspots and try connecting wirelessly there. If you are able to connect to other wireless networks, the issue is more likely with the single wireless network you first tried to connect to; contact the person that manages that network to resolve the connectivity issue.
2.Verify that your wireless card is enabled. If you are not able to connect to any wireless network, it is important to make sure that your laptop's wireless components are enabled. All modern laptops come with what is called a radio button, a way to enable or disable your laptop's wireless card with the touch of a button. The Dell D600 has the radio button assigned to the F2 key. To make sure it is enabled, hold down the Fn key on the bottom row of the keyboard and press the F2 key. A pop-up window on the laptop should now indicate whether your wireless card is enabled or disabled; make sure it is set to enabled.
3.Verify your wireless card drivers. Navigate to your computer's Device Manager by clicking "Start," right clicking on "My Computer," choosing "Properties," clicking the "Hardware" tab and clicking "Device Manager." Locate "Network Adapters" from the list of hardware devices and click the "+" icon next to it to expand its contents. Among the contents, locate anything with "Wireless adapter" in the name and check to see if it shows a "?" "X" or "!" over the name. If it does, or if there is no wireless adapter showing under network adapters, your wireless card may need to be replaced or may need a software-driver update. Contact the manufacturer of your computer or take the laptop to a computer-repair store for further assistance.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Dell Vostro A860 Notebook
I have belkin connect n150 and i have two laptops my one laptop is connect to wireless but the one laptop cant access to wireless it says no wireless network were found in range..
If your message is like this " no wireless network found in range make sure wireless on the computer is On". All you need to do is look for the wireless switch usually located on the side or the back of your laptop. Sometimes its near the F keys or start button. You may check your laptop manual to see where to locate the wireless switch , or you can check the laptop manufacturers website usually they gave information on where to locate or enable the wireless feature of laptop.
KA
Mar 30, 2011 | Belkin Basic Wireless Router
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
My Laptops Internet switch has stopped working
Then install your USB device with your CD
Then do this
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
Wireless networking
the key combo is F2 + Fn key (the fn key is located on the bottom row all the to the left) a little blue light lights up that looks like this ((o)) that lets you know it's on. press the combo again to turn of wifi communications.
Nov 15, 2008 | Gateway 7330GZ Notebook
Hardwiring laptop
hello!
the number ports are the actual ports at the back of the router where you will plug the cable to connect your computer directly to the router.
to find the network key for your wireless connection, you need to connect your computer directly to the router and access the setup page of your router. You need to go to the wireless settings and get the wireless network key from there.
Aug 27, 2008 | Belkin (F5D5231-4) Router
Linksys WRT54G2 Wireless Router Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
