Question about Electronics - Others
My battery keeps draining in my starcraft travel trailer evry time i put a fully charge battery in the camper in less then 2hour the battery is dead and with nothing on and all the braker off
  • 905 Answers
Charge your battery, and connect it back to the travel trailer. Use a 12volt test light to make the connection between the cable and negative terminal on the battery.
If there is something drawing power, the light will turn on. Remove the fuses from the DC fuse block 1 at a time, make note of the current rating for each fuse position. When the light goes out, the last fuse you removed is where the culprit probably lies. Now that all the fuses are out, plug each one in, individually, and see when the light comes on. Look closely at the light. Some notorious items that are left on are the antenna booster for the TV, the radio (volume turned down), and lights in the storage compartment. Some fridges will have a small heating strip between the doors. This heat strip may not be turned off with the fridge switch unless it is put into storage mode.
2 hours on a freshly charged battery is signifiant. The average Group24 deep cycle battery, in good condition, has a capacity of approx. 100Amp Hours. Most are able to sustain a load of 20 amps for about 180 minutes, around 3 hours. To deplete the battery in 2 hours, is a very significant current draw.
There are only 3 things that can singly draw down the battery that quick.
1) Furnace - but you would hear this one running.
2) DC Cooling mode on the fridge. Silent battery killer.
3) The breakaway switch for the electric brakes. When the plunger is removed, full battery voltage is applied to the brake magnets. A dual axle trailer may have 4 magnets, at 8 amps each, gives you around 32amp current draw. If pulling the fuses doesn't yield a culprit, the break-away switch is probably it. Remove the plunger, and push it back in. Watch the light as you do so.
Otherwise, look at your trailer connector. If it has been contaminated with road grime and such, it can cause a partial short between the charge and ground terminals.
Posted on Sep 10, 2010
  • Bob H
    Bob H Feb 22, 2014
    Also have the battery checked, it may have a bad cell.
Ive got a question about a 22 ft companion travil trailer
Plug it back in to the house electrics .then search for the inverter on the trailer .
Oct 13, 2016 | Coleman 1997 Fleetwood Sunridge Power...
1993 ranger supercab charging guage remains high all the time. When not started for a few days the battery will die.
Seems that you have a power drain. If you installed any electronics check to see if the wire has an open section that is bleeding the system.
Check to make sure that when the glove box closes the light in side goes off. A sprung glove door will keep the light on and will drain a battery in about 3 days.
If you put a trailer hitch on the truck make sure that the grounding is done correctly. Lighting harness to trailer, trailer to truck. A poor ground will cause the electrical leak and drain the battery if the trailer in attached for a few day, less than 3.
Dec 09, 2014 | 1993 Ford Ranger SuperCab
How to winterize a starcraft Launch travel trailer
Check you tube for video's, have seen a few good ones on there.
Sep 03, 2014 | Starcraft 2013 Launch 18BH
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
I need a manual for a 1996 Starcraft popup camper
hello there:
here is a link that will get you going in the right direction ok best regards mike
  1. starcraftrvclub : Messages : 142-171 of 2067 Other Starcraft Camper Clubs... Starcraft Tent Trailer - Owners Manual ... I have a 1996 Starcraft Galaxy with a 7.5 foor screen room that came with it. ...
    autos.groups.yahoo.com/group/starcraftrvclub/messages/142 - 50k - Cached
Aug 25, 2009 | Sport & Outdoor - Others
Looking for the following manual: 1984 Starcraft 24 Constilation
I have a pdf file for a Starcraft pop up trailer. You can email me at azkid53@comcast.net
I'd be happy to email it to you.
I can't remember where I eventually found it online, or I'd point you to that web site. I only know it took me a few days of searching.
Jul 13, 2009 | Sport & Outdoor - Others
84 Starcraft Stardust pop up camper repair/parts manual
I have a stardust camper which I converted to a utility trailer, what do you need, I can send you the manuals and paper work I have, the other stuff might not be worth the shipping?
May 11, 2009 | Sport & Outdoor - Others
I have an early 90's Starcraft pop up camper. I just went to hook it up to the van and the travel lights (running, brakes, directionals) don't work at all. All lights worked when the camper was stored last...
When you say that you have power up to the camper, do you mean power through the pigtail/wiring harness with the tow vehicle connected?
The trailer harness wiring is the only way to power these exterior camper lights, i.e., through your vehicle. There are no fuses within the trailer for the exterior lights. These lights are only fused from the tow vehicle's fuse box. So either the connections in the trailer harness are open, or they're open at the tow vehicle connection.
Do the turn signals work on the tow vehicle? If yes, then the only other thing to check is the turn signal flasher in your tow vehicle. A heavy duty flasher is recommended.
From the trailer, yellow, white, brown, red, green, is connected to your vehicle backup, ground (frame), right turn signal, left turn signal, running lights, respectively.
The trailer's blue wire is for an electric brake connection to your vehicle.
The trailer's small black wire should connect to the vehicle's hot, 12V lead for the interior lights. The large black wire at the trailer hitch is for charging an RV battery on your trailer, if it's supplied with one. Of all of these wires, only the large, 12 gauge, black wire goes to the 25 amp converter, which is fused, for the inside lights of the camper.
I hope this helps.
Apr 25, 2009 | Sport & Outdoor - Others
Auxiliary battery use
The extra battery is there because of the glow plugs and intake heater of the duramax. During cold weather both of these systems draw high amperage from the batteries. A single battery will function, but not as well as a pair.
Apr 08, 2009 | 2005 GMC Sierra 2500HD 4WD
Electronics - Others Logo
1,018 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
