Question about Kenmore 22422 Top Load Washer
Cold water rinse doesn't come in very hard. Just a trickle. Warm works fine. I just had the water shut off due to a water main break which is now fixed and water is back on. Warm wash fills fine. Cold rinse just trickled in and the washer is making a motor noise it never made before. I am renting this house and I think this washer is only 2 years old. Never done this before.
  • FixxItGirl Sep 08, 2010
    the video was mostly helpful but the guy kept putting his hands in front of the video right when he was doing the task he was describing. So, I couldn't see what he was doing! But his verbal instructions were helpful. I think the screens are probably clogged. The water sounds like it is working too hard to get through.
    President:
  • 1,430 Answers
Remove the cold water hose and check the screens for debris and clean. Also look inside the water inlet valve where the hose connects there should be a screen in there remove and clean. If this doesn't fix it the water inlet valve will need replacing. Here is a link that will walk you thru cleaning and inspecting the valve http://appliancehelponline.com/topwaterinletvideo.html
Posted on Sep 08, 2010
Testimonial: "This worked! Both of the screens were jammed with junk...had to use a high pressure hose to clean them well. THANKS! Everything is back to normal. :-)"
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Cold water runs slow
Turn the cold water off and remove the hose at the machine. You will find a screen located there and you will need to clean it out.
Apr 27, 2012 | Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water trickling out of machine during rinse cycle
Check cold water pressure to washer. if pressure o/k then you will probably need a new cold inlet valve fitting.
Dec 13, 2008 | Washing Machines
Rinse cycle, water won't work
It sounds like you either use warm or hot water for the wash cycle. If this is the case, you probably have a cold water solenoid problem on your water inlet valve (also known as a mixing valve on some washers). Most people use warm or hot water on the wash cycle. The water inlet valve has two solenoids. One for hot and one for cold. It uses a combination of the hot and cold solenoids to make warm water. The rinse cycle on most washers is a cold water rinse only, however. This would explain why the water appears to flow normally when it fills during the wash, and only trickles when it rinses. If you live in an area that has hard water, or if you use well water, these valves commonly clog with sediment. You can shut off the water, remove the hoses, and attempt to clean the sediment screens to see if the water flow improves. If it doesn't, you will need to replace the valve. The following link epxlains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
I know the link says this is for a Kenmore or Whirlpool, but also applies to a Roper. A replacement valve can be ordered on line at searspartsdirect.com. Just type in the model number and the part you need is located under the "Controls and Rear Panel" heading as item number 18 (part #285805). This is a very simple and inexpensive fix if you wish to perform the repairs youself. Not to mention, you can potentially will save hundreds by avoiding the labor charges of a service call. I hope this helps you. If you require additional assistance, please let me know. Hopefully, a good cleaning will do and you won't require parts.
Sep 12, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore 22422 Top Load Washer Logo
165 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
