Hi, the fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch.
hia tahnk you forthat i have done what you said and i have now replaced the pressure switch but has not made aany difference will not empty or spin fault code f05 still comes up
