Question about Samsung Televison & Video
MY SAMSUNG TV :MODEL SP4R1HL1XSHI Version SV01 was working alright until we moved to a new location. Now I have the visuals in the top quarter of the screen presenting double image and a small red 'crest'. What could be wrong and where can I fix it in Lagos Nigeria? I have not as yet tried to get it fixed, wanting your advise first. Thanks for your anticipated assistance. KOLA
  • Samsung Master
  • 8,457 Answers
Tv have problems known as a convergencce problems.Check ur remote go into tv menu.Go to convergence adjustment,try auto convergence.The auto convergence din't fix ur problems.Than the tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.Try the website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Akai/Samsung DLP tvs used the same convergence board.
Posted on Sep 08, 2010
Heater dont work when foot off gas pedal
Can you quarter turn your carborator up so more gas flows through your carborator? (Depending on what model and year car/truck you have it may not have one to adjust it would be located under your filter on top of your engine and the adjustment would be a screw with a spring on it lefty loosy tightly eighty so turn it right to tighten but not too much just a quarter at a time until the heater stays on) hope that helps
Dec 11, 2014 | Cars & Trucks
Purchased an rca home theater pkg in 1994. recently moved to new location, now amp display is stuck on "wait". cd player appears to be working, but no sound. 135 watt hi-fi audio amplifier...
There are some worn out capacitors in the power supply. Most can be visually detected by looking at the tops of the round metal cans. If they are not flat on top, then it needs to be replaced.
Dec 21, 2010 | RCA Audio Players & Recorders
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Distored picture and a rainbow aura around objects in the pictur
this CRT TUBE internal Problem, first use CRT Rejuvenation Device. If dont repair you must change CRT TUBES
Oct 30, 2009 | Samsung Televison & Video
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Sky remote tune to samsung
3. Press tv again
Samsung Code: 0060
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
Televison & Video Logo
227 people viewed this question
Jerry Greenberg
Jerry Greenberg
