Question about Garmin nuvi 205 GPS Receiver
It is just saying maps are locked - Garmin nuvi 205 GPS Receiver
    President:
  • 1,514 Answers
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Posted on Sep 09, 2010
My garmin nuvi 200 says no detailed maps found
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message "No Detailed Maps That Support Autorouting."?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message "No Detailed Maps That Support Autorouting" disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for "Getting your unlock codes".If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the "No Detailed Maps That Support Autorouting" message.
Aug 14, 2012 | Garmin Nuvi 200 Automotive Gps Receiver
I turn on my gps and it says no map data available unable to use device
There are 2 possibilities; Either the map has become unselected, which is most likely,or the map is locked. You can find solutions to both these problems at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There may be more information there than you need so to find how to select an unselected map go to paragraph 5. To unlock your map start at paragraph 2.
May 21, 2011 | Garmin nuvi 255W GPS Receiver
My maps are gone how do I fix it
The map may be unselected. To select it;
  • Press TOOLS (the spanner icon) in the bottom right corner of the WHERE TO and VIEW MAP screen
  • Press SETTINGS (or LOCALE on models that don't have a settings icon)
  • Press MAPS and then MAP INFO at the bottom of the screen
This should show you the maps installed on your satnav. There should be a tick beside the map name if it's selected. If not press the map name and the tick will appear. This should solve the problem.
If this does not solve the problem the map may be locked or deleted. If the map is locked it should say so at the map name. If there's no map name then the map may be deleted.
You can get details on how to unlock your map at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
If the map has been deleted you may be able to download it again from the garmin website depending on how old it is. Generally you can download the map for about 6 months after it was first installed.
  • To download the map again go to www.garmin.com
  • Click on the myGarmin tab at the top of the page.
  • If you haven't already registered your satnav do so on this page by clicking "Register your garmin product" and follow the prompts
  • When you're registered log in using your username and password
  • Click on the myMaps tab at the top of the page
  • Your satnav name will be on the left hand side of the page and your map name in the centre. On the right it will either say "No update available" or "Update available"
  • If there's an update available downloading and installing it will solve the problem but you'll have to pay for it. Alternatively click on where it says "Details" in blue under your map name
  • This brings you to a screen where, if the map is not too old, you get the option to download it again. Click on "Download again" and follow the prompts to reinstall it.
Jan 25, 2011 | Garmin nuvi 265WT Car GPS Receiver
My garmin powers down while installin gnew maps.
There are 2 possible reasons for it to say there are no detailed map available. The most likely reason is that no map is selected. Press Tools, then Press Settings, then press Map and then Map Info. There should be a tick beside the name of the map installed on the satnav. If not press the map name to select it. A tick will appear at the side of the map.
The other reason is that the map may be locked. You'll need to go to My Garmin, and then Maps to get the unlock code.
Jul 30, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin GPS say's the maps are locked how do i unlock them
Where did you purchase the maps? If they are from Garmin, contact Garmin and they will walk you through the steps to unlock the maps.
Dec 26, 2009 | Garmin NUVI 710 Car GPS Receiver
Euor maps say locked when i put sd card in sat nav
You have a "LOCKED" Gps....... you need to unlock it.
Sep 01, 2009 | MyGuide 3100 GPS Receiver
Global map 5200c loading problems- navionics platinum hot maps
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out and it works every time.
Mar 22, 2009 | Lowrance Globalmap 5200c Color...
Maps locked
are your maps unlocked when you bought the GPS? try registering the product on garmin website... it should unlock the maps...
Jan 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Can't get maps to unlock
Call Garmin support @ 1-800-800-1020
Feb 09, 2008 | Garmin Quest GPS Receiver
Uploaded Map Update 2008 City Navigator North American NT now maps locked
I held on the phone with Garmin for about 2 hours, but they fixed my unit, PATIENCE!
Oct 19, 2007 | Garmin StreetPilot 2720 GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
427 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
