Question about GE GSS20IEP Side by Side Refrigerator
My water preasure in door is terrible takes forever to fill glass
  • GE Master
  • 1,606 Answers
Either replace the water filter or replace the water valve ( located behind the refrig where the wall water line connects to ) or , install the water filter bypass piece which came with the refrig . ( This will tell you if the filter needs replaced ) .
Posted on Sep 09, 2010
Just got a Kenmore he washer and dryer I'm wondering why my washer does not fill with water to cover the clothes
Either the fill valve is not working or the controller is not sending a signal to fill valve to open. If parts needed check here Search Over 2 1 Million Appliance Parts
Sep 10, 2017 | Kenmore Washing Machines
Why does it take my washer so long to complete a cycle
If you're filling from cold then the water has to heat up if you select a hot wash. If your water preasure is very low then it could take a long time to fill every time.
Sep 30, 2014 | Kenmore Washing Machines
Is there a malfunction with preasure switch if water is pouring out of door
is the seal cut or ripped on the bottom...have you cleaned the glass as this will help it to seal the door ie remove any limescale on the door glass
Mar 15, 2014 | Splendide Washing Machines
Water stops flowing when door is open
This is normal. A lot of refrigerators will cut off water flow when a door is open. It can be useful when you have guests over who don't know about it and start filling their glass. You open the fridge and take your time getting something while they stand there and think their glass is filling.
Jun 11, 2012 | Refrigerators
Takes forever to fill water bearly comes out
The water line valves will need to be replaced. The are electrically operated valves so remove all power before replacing them. They are located under the hood, top rear of the machine.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchen aide ksrg22ftss fridge wont make ice and
check your fill solenoid located at the bottom back of fride the valve may have a verry fine filter inside the valve ether clean it or replase the valve valve cost aprox 20,00 thanks from gilles
Mar 15, 2009 | Refrigerators
GE GSS20IEP Side by Side Refrigerator Logo
100 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
