Question about Maytag Washing Machines
Model - Maytag plus 2 speed. Will not spin everything else works. Machine ten years old
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 08, 2010
Motor starts spinning but why does it then seem to "stutter" and not reach top speed?
one of two things, this is a newer machine and it doesn't work the same way as the older machines and ramp up to full spin speed, Everything is plastic for gears so they have to get much of the water out they can before hitting full speed. or second the belt is slipping. You didn't leave a model so I to a guess to how the machine really is.
Mar 28, 2016 | Maytag Washing Machines
Maytag dependable care quiet plus heavy duty 2 speed super capacity washer fills with water but won't agitate spin or drain
I presume that you read your manual on that problem. I have a Maytag. So far mine is not quiet so I cannot help you with that area but if your washing machine is not spinning or agitating if you are still under warranty FIRST CALL the manufacturer. That way you will not void your warranty. If it isn't under warranty, CALL them anyway. The help line knows a lot about those problems. Now on my old one - not one of the new ones - I had a warranty on appliances. Washer was included. They told me that the belt was not turning something in the motor. It was either worn or broken. Either way don't you try to fix it. Unless you are a machine repair person - do not try to get to it. You cannot imagine how many little pieces were included in that motor. Even a motor scheme sheet for your machine will not be worth your time. They did fix mine. I just gave you the speech the repair person gave me. The house call was not very much. That was back some years so -25 - 50 dollars for another 10 years of usage was good. I read the instructions to everything. That is just my inquisitive nature. However, that may be a headache to you. So get your manual out and go to the troubleshooting section. If you don't see an answer, look on your washing machine and get the model AND serial number. MAYTAG used to have that information on the lid or door somewhere. It is very hard to use even with a magnifying glass. Choose a time you are in a good mood. If you cannot find it, call the store where you purchased it. They can give you all of that information and where to call. Or they can tell you your warranty information and some of the reasons it might be happening. Last, go ahead and dip that water out of the machine tub. That will be way more water than you anticipated. If you haven't, remember you are working with water and electricity. Put on your boots - just because it is a messy job. Now, before you start UNPLUG EVERYTHING. Last, if you have an older model, it might take a while to get parts. Be prepared to do a little light sink sudsing and wearing clothing more than once (smiling.) More than likely this is a Maytag repair problem. If you cannot find your warranty information, when you call the retailer, they have it. If you bought it at Home Depot or Lowes they will have ALL of your information. Isn't technology wonderful??
Jan 23, 2015 | Maytag Washing Machines
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
My Washing Machine won't drain, the motor sounds but no spinning happens. Maytag Performa Model # PAV3240AWW
you have blocked filter or pump has an object in it if machine is about 2 to 3 years old pump may need replacing
Oct 19, 2008 | Maytag Washing Machines
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG MAH5500BWW Fails to spin properly clothes wet
I replaced the motor and circuit board but that did not fix it. I changed the out of balance switch and the shock absorbers or snubbers. I think the ultamate fix was the snubbers. it has worked great since. They wear out like your car shock absorbers allowing the drum to shake too much triggering the out of balance switch to stop and restart the spin.
Oct 22, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
