Question about Texas Instruments TI-30 XIIS Calculator
I've tried to get out of the degree setting many times it just shows up on my screen I want it off! How?
  • kakima Sep 08, 2010
    Okay, what setting do you want it in? The angular mode is one of Degrees, Radians, or Grads. One of those is always going to be on. My previous solution told you how to change it. Or do you want to change between DMS and decimal degrees?
  • kakima Oct 14, 2010
    Are you ready to use a razor blade on the circuit board to cut the trace?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Whatever angle mode you're in, the calculator will display that. So, if you switch to radians, the DEG will disappear from the screen but the RAD will show up instead. That's just the way the calculator works.
Posted on Nov 04, 2010
The unit is on Heat, Fan Auto it's 36 degrees outside, Thermostate set on 73 Actual temp inside 70. Unit runs continuously. How can I get more heat. I tried Emergency heat and that doesn't help.
Have you cleaned the air return filters ? Wash them, don't vacuum or brush them. It damages the filter screen. Sometimes a thermostat will be out by a few degrees. If the filters are clean, try turning the temp down a bit to 65 degrees and see if the air con shuts down. ( If your room temp is showing 70, it should switch off the machine) If it doesn't turn off, keep reducing the temp by 5 degrees at a time and wait a few minutes each movement to see if and when it shuts down. If the machine keeps running, I would suggest your thermostat is shot and you will need a new one.
Jan 04, 2016 | Heating & Cooling
Ipad screen not rotating
Hit home button 2 times then slide ur finger copper and click the cerved arrows
May 18, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Bios Problem
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jul 30, 2012 | Toshiba Satellite A660-ST2N02 Laptop...
My Honeywell Thermostat won't stay at the temp that I set it at!
You are likely running a schedule. When you go to tstat and change the temp it is a temporary setting that will expire in a given amount of time. 1, 2 3 hours etc. "HOLD" can sometimes bypass the schedule, "RUN" returns to the schedule. Not sure what model tstat you have but you have to exit your schedule.
Apr 18, 2017 | Honeywell Heating & Cooling
Ho can i get deg off the top of mt calculator i think it is making my answers wrong not all but some of them when i try to check my work
Maybe some of your answers are wrong, but I can assure you that it has nothing to do with the poor deg indicator sitting on the top of your screen.
The indicator is there to remind you that the angle unit is set to degree, meaning any number you feed a trigonometric function is considered to be in degrees, and that any value calculated by an inverse trigonometric function is in degrees.
If you prefer to work in radians or in grads, all you have to do is change the settings of the calculator.
To change angle unit:
Press [SHIFT][MODE] and choose
  1. 3:Deg for angle unit in degrees. Screen shows D
  2. 4: Rad for angle unit in radians. Screen shows R
  3. 5:Grad for angle units in grads. Screen shows G
The calculator crunches number according to your specifications. It obeys your orders. Only YOU know what you are supposed to do.
I suggest you look at the manual that shipped with your calculator. Lookk for exemples of the calculation you want. Make a note of the exemple numbers and check the appendix for the particular exemple. The appendix will show you all the key strokes.
Hope it helps.
Thank you for using FixYa.
Nov 21, 2009 | Casio FX-115ES Scientific Calculator
Screen problen
hi,
welcome to fixya
what u can try is this
Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
pls and pls rate this solution for me pls......thanks
Feb 16, 2009 | Compaq Presario Notebook
My sony ericsson w600i just went blank
i have white screen in W600i model please solve this problem
Sep 10, 2008 | Sony Ericsson W600i Cellular Phone
Texas Instruments TI-30 XIIS Calculator Logo
71 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
