Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Will dispense cleaner but will not pick up. Vacuum portion works somewhat but maybe not enough?
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 08, 2010
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
My bissell carpet cleaner won't dispense the
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
fdghd
Apr 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
The Hoover Steamvac Widepath will NOT pick up water. The dispenser with cleaner DOES have water. The TANK that would receive the dirty water is NOT full. All tanks are on properly and the machine will...
Sounds like a clogged air path (no vacuum action) from the floor pick-up to the collection tank. Take the tanks off and deal with the vacuum problem alone. The collection tank should have a air exit vent--is it clear? Check the interior hose that you repaired--is it clogged? Remove the bottom plate and inspect the air path from it. Because this machine deals with water, clogs can become like concrete! Hope this helps!
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Too much solution being dispensed--carpets very wet--running out of solution before even 1/3 of room cleaned
The cleaning solution tank is only sufficient for part of a room, unless the room is very small.
Are you following the instructions for using the cleaner carefully? The machine has to be pulled backwards (towards you) at a steady pace in order for the vacuum to pick up the water that is dispensed. Do not use it like a normal vacuum cleaner - that will not work.
You need to start facing a wall, and pull the cleaner towards you, moving at about one foot every two or three seconds. The vacuum will then pick up the water that has been dispensed and the carpet will be damp but not sodden.
Apr 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Electrolux Harmony Not working
maybe it is clogged. does the light go out if you turn it on with no bag?(for testing)
is the roller spinning?
Jan 07, 2010 | Electrolux Harmony Canister Vacuum -...
Doesn't pick up water
Is the vacuum motor running? Are the pathways from the floor tool to the recovery tank clean and clear?
Jun 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuum pick up stopped
I noticed a flap covering the filter and this hindered the air flow. I made sure it wasn't covered and, Wa-La, it works perfectly again.
Thanks anyway.
Dec 22, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
121 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
