Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
I have a lawn-boy self propelled mower,model no. 10247-8900001 & up.When i start it it is like a fog machine and it is like the choke is on all the time.I don;t see any adjustments for this.When it sits over night raw gas comes out of the exhaust.
  • 3,740 Answers
You have some debris in the float needle valve. It will require that you remove the float bowl and the float. To remove the float you will need to remove the float pin and drop the float straight down. The float needle will come out with the float assy. Then take some carb cleaner or compressed air and shoot into the float needle chamber to clear the debris.
Check the float needle tip for any rough spots. It should be smooth. The reinstall the float needle and float assy making sure to note the float pin position is the same as originally installed.
Last check before installing the float bowl. With gas available to the carb lift the float GENTLY to the level position. Fuel flow should stop. If it does not stop then there is still a problem with the float needle or the needle seat is damaged and will have to be replaced. The needle and seat are in the same package if you purchase a replacement. The seat can be difficult to get out of the tiny hole. A really hard piece of wire with a mini 90 bend on the end will often do the trick.
If for any reason you have to remove the carb.. do yourself a favor and take PICTURES of the linkages and spring(s) so that you can re-install them correctly.
If you need more assistance please pass me just the ENGINE number so I can pass you the diagrams with part numbers if necessary.
Thanks for choosing FixYa.
Kelly
Posted on Sep 08, 2010
How do adjust for Speed stability on Lawn-Boy mower. It hunts up and down.
Speed control for motor is controlled by an automatic governor, so there isn't any adjustments. Surging is caused by an air leak. Has the air filter been changed? Spray card cleaner around that side of the engine to find the air leak. Does it have a choke adjustment? Make and model would be handy in answering this question!
Oct 18, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
Why will Ariens lawn mower starter engine not turn over?
These machines have carb and coil issues. Check for fire. Nice when new, but once a little age creeps in, the engines just aren't that sturdy. Sorry, but as a small equipment mechanic, I don't recommend Lawn Boy. Next time, buy another brand.
May 30, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
My lawn mower starts up but seems like it has no power to rotate the blade. Added oil, replaced air filter and the spark plug but still has no output power.
Is the choke stuck on? That could do it. Does it rev high enough ? May need adjusting. You say you added oil was it low enough you have almost seized the engine. Just a thought
Sep 21, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Engine starts sputters then shuts off
probably a dirty carb. or if this problem is occuring when the engine has been run and is hot and its the new style easy start engine with auto choke ( no primer or choke lever) then the auto choke unit coud be faulty
Aug 21, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Starts but doesnt run
Is the choke on?
Is the fuel tank full?
It sounds like a fuel problem, if the tank is full and the choke is not on, then I would check for dirt in the carburator.
Aug 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
May 31, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
743 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
