Question about Amana ALW480DA Top Load Washer
Need to install drive belt on amana awl480daw
2 Suggested Answers
  • 1028 Answers
SOURCE: How to change drive belt on Amana washer
remove the 4 bolts holding motor to tub and frame remove wire harness from motor remove pump hoses turn assembly upside down 3 torx screws hold pump to motor note routing of old belt around idler pulley and pump studs reinstall in reverse
Posted on Apr 24, 2008
How to install the drive belt on an Amana NED7200TW dryer?
Take a look at this routing diagram.
Here is a video to walk you thru the process.
Oct 23, 2012 | Amana NED7200TW Electric Dryer
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
Installation Tips: Ribs against drum
For Amana all models will look like this
Installation Tips: Ribs face toward drum
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 02, 2010 | Dryers
The drive belt broke
Hello there and thanks for cfhoosing fixya
Here is a listing of the belt diagrams and a part number for you ok?
Belt, Drive
Item # 529597
img-descriptiontab-on.png img-repairgurutiptab-off.png Dryer belt. This is the most common belt used on Whirlpool, AMANA Kenmore, Kitchenaid, Roper, Estate and other dryer brands. The belt is flat, 92-1/4 inches long, 1/4 inch wide and has 4 ribs and 3 grooves. It replaces many other belts, including some with 5 ribs and 4 grooves.
img-descriptiontab-off.png img-repairgurutiptab-on.png See our dryer belt diagram to see how this belt should be installed around the motor and idler pulleys.
Watch Video
Order now and choose FedEx 2Day or FedEx Overnight shipping and this item will ship out today - or it's FREE!
$11.20 Quantity:
In Stock
Feb 05, 2011 | Amana NGD5400TQ Dryer
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
Amana washing machine will not spin. it agitates & the water drains out fine.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 30, 2010 | Amana ALW780QA
Hello! The belt broke on our Amana Mod.# DLW330RAW . Could you explain how to install the new belt? Thanks Ron
Remove the bottom kick plate.
Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
Mar 17, 2010 | Amana DLW330RA Top Load Washer
Amana AL480DAW- burnt smell, smoke, still fills then dicharges
You are right on about the belt. If the tub every gets jammed by a full load and has trouble turning, the drive belt can get heated up ( kind of like spinning tires on the road...you get a smell and everything still works).
I would suggest pulling the front cover to expose the belts...look underneath. There are usually two one for the drive and one for the pump. I'd replace them both... with extreme heat, it can change the belt enough that it won't operate correctly with bigger loads.
K
Jul 10, 2009 | Amana ALW480DA Top Load Washer
Installing a drum belt on an Amana NDE2335AYW
call me if you'd like and i'll walk you through it Jim 417-926-0106
Dec 20, 2008 | Amana NDE2335AY Electric Dryer
Installing dryer belt on amana LE2910W
Please view Amana dryer belt installation diagram amana.gif Diagram A
Disconnect dryer from the power source before servicing!
In assuming that you already have the front removed, you can raise the top by removing 2-5/16" screws located in each front corner that secure the top to the side panels. Then remove th 4-5/16" screws from the bulkhead that secures it to each side panel. Then use the diagram above on installing the belt properly.
Let me know if you need any more information.
May 28, 2008 | Amana Dryers
Amana ALW480DA Top Load Washer Logo
55 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
