Question about Danby (DAR604BLS) Refrigerator
My fridge is too warm. I have tried turing the temperature control up and it didnt help.
  • 3 Answers
Need more info. mo#
Posted on Sep 08, 2010
Hiw di I set the temp to the correct temp
turn freezer to mid point and try fridge on 3.5 as a starting point.
Keep the refrigerator temperature at or below 40° F (4° C). Thefreezer temperature should be 0° F (-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these temperatures and are generally inexpensive.
press the helpful button and check link below
Fridge temperature guide Kitchen
Jan 29, 2016 | Refrigerators
Temperature playing up going up not down
Refrigerator Not Cooling Enough - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
If the refrigerator is running, but not cooling at all or is not cold enough, several ... To view a short video on adjusting the temperature on set point models: Play ...
How To Fix A Refrigerator and Freezer That's Too Warm ...
www.partselect.com/Repair/Refrigerator/Refrigerator-Freezer-Too-Warm/
If your fridge and freezer is too warm, don't give up - we can help. ... The cold control is a temperature controlled switch that supplies power to the compressor ...
Nov 21, 2015 | Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Fridge temperature too warm
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
Dec 06, 2013 | Refrigerators
Only one temperature control??
Good day,
Yes, they are made. The temperature in the fresh compartment will be no issue, since you have control in that compartment.
The engineers designed the balance between the two compartments so the freezer would be normal if the following conditions applied.
1. The room temperature is between 70 and 90 degrees.
2. The machine has normal usage. I.E. 8 to 20 door openings of the fresh food door.
The freezer would start getting warmer if the room temperature dropped much below 70 degrees. or..
If the machine had extremely light usage with very few
door openings, or a combination of both situations described above.
With dual controls, and both set at normal, the above conditions would occur anyway, except you could over ride the normal settings to compensate.
Many people have this setup, and experience little trouble, but without knowing your life style replacing it would be your choice based on the facts given.
Thanks for using FixYa
Dec 23, 2009 | Refrigerators
My 9 yr old Kenmore Elite fridge is warming up!! The freezer is fine!!!! Model 3 106*74902401 Seriel # ES423704 Manufacture date is 10/2005, I purchased it in Dec of '05 and it's been WONDERFUL!!
This problem sounds like a damper control broken or frozen.
Lowering the freezer temperature may help to fix the problem as the damper sometimes freezes and not able to open to cool down the fridge side.
If lowering the freezer temperature doesn't help, you may need to call for a technician to fix or replace the damper control.
Also, be sure the door closes properly and no air comes in or out from the fridge.
Dec 18, 2009 | Computers & Internet
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Fridge too warm
first, verify that the fan is running in the freezer compartment. second check that there is no airflow blockage between freezer compartment and refrigerator compartment. if that does'nt solve the issue verify the defrost system is working.
Mar 28, 2008 | Refrigerators
Blinking temperature control
You need a new High Voltage Control Board.
Oct 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
Danby (DAR604BLS) Refrigerator Logo
114 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
