My lcd tv polariod 1511 TLXB only get No signal
  • van12358 Sep 08, 2010
    the problem is when turn on the screen show "no signal" but after that the screen is black.
  • 736 Answers
It sounds like the television is on the wrong input. It may be tuned to the incorrect channel if you are using the tuner. Check your connections. Make sure none of the cables going between your television and whatever device it is connected with. If you are using the television's tuner to a direct cable connection with no cable box then complete another channel scan. If you are using a coax cable connected to a cable box or satellite receiver make sure your television is tuned to channel 3.0. If you're connected with RCA/composite cables or component cables to a device and you are on the correct input the cables may need to be changed or the device may no longer be operational. Try another input, another device, and different cables. It is most certainly not the television.
Posted on Sep 08, 2010
  • Loretta Northcutt
    Loretta Northcutt Sep 09, 2010
    You may need an Inverter Unit or even an LCD Panel. The inverters need to be checked because they might be loose. The connections on the Inverter Unit need to be checked. The ground screws may be loose also.
Code for comcast remote
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
Feb 20, 2010 | Polaroid 1511-TLXB 15.4 in. LCD Television
After powering up the TV , the screen goes really dim (almost black) after only a few seconds. Can you troubleshoot this problem with me?
your back light inverter is faulty ( they are like starter motors for tvs ) you will need screen model number that is on label inside tv on back of screen )
Nov 08, 2009 | Polaroid 1511-TLXB 15.4 in. LCD Television
Polaroid 15" HD Widescreen LCD 1511-TLXB, turn on, stays on for about 30 seconds to 1 minute and then screen goes black, no sound, no menu
Do you have to turn it back on with the remote after this?
If so, then you may have set a timer by accident through the menu system.
More information would be required.
Aug 04, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
No signal without a digital convertor box.
You must have a tuner, but the one built into the TV will work fine. Have you scanned for available channels after connecting your antenna?
Jun 28, 2009 | Polaroid 1511-TLXB 15.4 in. LCD Television
VGA shut down
call Polariod
replace 'box'
(their description, not mine)
May 07, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
POLAROID 1511-TLXB LCD TV Remote Code for Verizon FiOS STB
I posted that as a point of information. I noted from searches that other people were having remote code problems w/that TV set. Code 0205 worked for me.
Aug 23, 2008 | Polaroid 1511-TLXB 15.4 in. LCD Television
1511 TLXB used as PC Mon
You have to use the TV remote to access the set menu.
From there, you can set the TV to monitor mode.
Jun 17, 2008 | Polaroid 1511-TLXB 15.4 in. LCD Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
