Question about KitchenAid Refrigerators
Refrigerator model kscs25inss01 water dispenser not working. ice maker is ok. water vale (part # 2315533) not humming/vibrating when water dispenser activated.
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
SOURCE: no water to ice maker
We had a problem with ice maker not making ice. After alot of concern it turned out we just needed to replace the filter.
Posted on Aug 07, 2008
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
SOURCE: Ice Maker doesn't work
i press ice dispenser . and ice will not come out an light goses dimm please help
Posted on Jan 14, 2009
Sea Breeze
  • 4655 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
Ice maker not producting ice
Check that water is turned on.
Check temps in freezer below 15 degrees F.
Check that arm on Ice maker is not locked up in the off position.
Test water inlet vale by applying power if valve poers up and dispenses water ok replace the icemaker assembly.
Nov 02, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water not coming out of dispensor
two problem one water vale are the line were water come out is frozen the water splashes back and line freezes are water vale leakes
Jun 01, 2009 | Refrigerators
Kenmore Coldspot Side by Side Model #57562791
hi debie normaly the life of these ice maker range from 3 to 4 years then the wtr hardness eats them up and the mold start leaking wtr but if is a fairly new model the you have a faulty wtr vale that is not closing sending wtr all the time to the ice maker repl the ice maker is you see is peeling of the texture inside if it is ok repl the valve
Oct 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water going into ice maker, water dispenser works great.
check fill tube that goes into ice makes if filled with ice water vale bad or vale still bad not letting water in
Apr 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser not working but making ice
GW, the valve on your refrigerator is actually a "2-in-one" kinda setup. One water line comes in, but splits at the valve to perform the separate functions, chilled water and ice. It's called a dual coil valve... one coil for each function.
Generally speaking these are the Achilles heels of the plumbing system. The easy way to check it is this... pull the fridge away from the wall, have someone get behind it down where the water line goes behind the cardboard cover to listen. Now have someone try to get water from the dispenser. If you hear the valve energize and get no water, you have a bad valve assy. (You'll hear a low "hummmm" at the valve when it's energized)
Replacement is easy. The part number is 2315533 and lists for about $45.00. Turn the water off, remove the cover from the lower rear, remove the valve. Remove the tubing and electrical connectors and install on the new valve, then reassemble. All you'll need is a 7/16" wrench and a 1/4" socket or nut driver.
If you don't hear the low hum I mentioned, remove the cover, reach in there and touch the valve's mounting bracket and have your helper try to get water again. You should feel the bracket vibrate slightly. If so, see above.
If the valve makes no noise and doesn't vibrate, we'll have to look deeper. Let us know what you find.
Oct 23, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
