Question about Cosco Juvenile Scenera Convertible Car Seat - Daisy Daze
How to put cover back on, I washed it and don't know how to put back on
    Problem Solver:
  • 12 Answers
Http://www.coscojuvenile.com/usa/eng/Instructions?ProductNumber=22216LLP
Just need the manufactures date to get instructions..
Posted on Sep 08, 2010
I have a Edinburgh delux booster car seat. I needed to wash the cover and unbuckled everything and now I don't know how to put it all back together. Please help me I've tried googling the seat
Contact a certified Child Passenger Safety Technician (or equivalent if you are not in the USA). www.nhtsa.gov
It MUST be reassembled correctly. Do not guess!
Apr 11, 2013 | Baby Gear
I took my car seat apart to wash it and I don't know how to put it back together
We would advise you contact the manufacturer of the carseat as the likelihood is that the unit will need to be sent to specialist engineers to inspect and put back together correctly. Due to safety implications of the harness being incorrectly fitted it may not be possible to do this yourself.
Dec 19, 2012 | Baby Gear
I dont know how to change it
Hi Mateo,
I suppose you don't know how to open the backside of your watch, to replace the battery.
If that is so, check the back side of your watch. At the edge of the centre cover, or just under it, there is at 1 place a little notch of a view millimeters. Juse a small screw driver or tweezers for instance to lift it up. If you don't succeed, the cover might be tight and sticky. So you need to put the back side of your watch on a hot and wet cloth. That might help to loosen the sticky edges.
Good luck ;)
Andre
Oct 20, 2012 | Watches
After washing a load of clothes I am noticing a brownish slimy substance on the clothing. What is it and how do I get rid of it?
Open the lid. Look straight down into the bottom of the tub. There is a round gray cover about three inches in diameter. Grab hold of it and pull it off. It should come off fairly easily, but if not pry it gently with a flat blade screwdriver. There is likely a gob of the brownish stuff in there. Clean it out and put it back on and this will likely take care of the problem. Note there are three little clips that fit into three grooves when replacing the cover. If this does not take care of the problem take the gray cover off again and you will see a 10 mm nut. Take it out and then lift the bottom plate out of the washer and clean it up. If that doesn't do it, I don't know the answer, but this is what worked for me.
Sep 19, 2011 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Please help I've put my grey quinny buzz seat
Good Afternoon
As long as you wash it maximum temp 30 degrees on handwash or delicate cycle it should be fine.
To be safe wash it by hand with mild detergent rather than putting in the machine.
Jul 14, 2011 | Quinny Baby Gear
I have a hoover optima, and I have just cleaned the filter, when I put the filter back in, water leaks out from it.
CHECK IF YOU HAVE REPLACED THE COVER PROPERLY. IF IT DTILL LEAKS THEN YOU HAVE TO REPLACE THE GASKET.
Regards.
DON'T FORGET TO RATE MY SUGGESTION
Jul 06, 2011 | Hoover Washing Machines
January 31, 2010 Kenmore top loading series 80 leaking from bottom toward front. It started during a wash cycle. I put two wet towels back into the empty washer and put on spin, leaking reoccurred. ...
is the pump leaking?or you could have bad tub seals,follow the center trany shaft up to the tub and see if it leaks there,is it noisy when spinning,you gotta just get in there with a light and look around to see where the water is coming from,if you sent pictures they didn't show up,remove the front cover,take out the two screws that hold the console down,remove the two clips with a screw driver and unplug the lid switch wires and pull the cover back and remove it
Jan 31, 2010 | Washing Machines
FP fault 43
code 43 is an out of balance switch problem.Once replaced, would fix the issue.
One trick that might work ;-
I unscrewed top cover, then unscrewed and lifted up the grey computer cover. The balance switch is underneath on the right with a yellow and white wire coming off.
I removed switch from clip and then removed the wires/clips from contacts. There was definitely corrosion on the contacts. I soaked switch overnight in vinegar. Then rinsed with water. Then dried switch out for day.
Put it all back together and am now on second load of washing.
Thanks.
Jul 01, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Can i wash my covers
sure, remember to only dry with a light air tumble. not extreme heat. the full heated dry will cause shrinkage.
Mar 01, 2009 | Graco ComfortSport 8639 - Grey
Cosco Juvenile Scenera Convertible Car Seat - Daisy Daze Logo
190 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
