Question about Maytag MDG6000 Dryer
I cannot find the lid clips on my Maytag dryer MDG6000AWW to remove the top. Any suggestions?
  • Maytag Master
  • 3,289 Answers
The lid clips - if I understand you correctly - do not need to be accessed - you merely pry the front of the lid up by slipping a screw driver between the lid and the front panel - near the corners. The top will lift out of the clips and lift up - hinged at the rear of the dryer. I don't know the MGD6000AWW in particular, but there are many dryer belt repair videos to look at - all of which require that the top lid be removed. Have a look at these videos to get an idea of what I'm describing.
Posted on Sep 08, 2010
  • michaellstar Sep 09, 2010
    There are no lid clips on this dryer. After trying a number of different things, I found that the front of the dryer comes off by removing the door and two screws on the door frame. The top is secured down with two hooks that have to unscrewed once you get the front panel off.
  • Steve Sep 09, 2010
    I'm glad you got it figured out. I've done more than a few dryer belts (but as I said above - not your model in particular) and not seen that type of dis-assembly. Hopefully you were able to scan through the videos and found a dryer that looked like yours to see how it was done.
Maytag MDG6000AWW- How do I get inside to test parts ?
Check here for the diagram - this should show you how to access everything. http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=MDG6000AWW&mfgModelNum=&fkMfgID=1
Aug 02, 2012 | Maytag Dryers
How do you open the lid? belts are squeaking
Number 3 is a spring clip. Use a putty knife to release em like this:
Innards look like this:themobilian_2704.jpg
Use Zoomspout oil to kill them squeaky noises. Remove the rollers and shine up the shafts with sand cloth. then oil em and put it back together. You need to sit the dryer on a table to get the belt back on. Doing it on the floor is tough.
Jul 30, 2011 | Maytag PYE2300AY Electric Dryer
Model #MDE8057AYW I need to know how to get the lid off so I can see if I need a new belt
1.Unplug the electrical cord of the Maytag electric dryer from the electrical outlet.
2.Open the dryer door and locate the four screws on the inside,unfastening the screws with a screwdriver.
3.Pull on the corners of the top front panel,rolling the corners forward to release the clips.
4.Tip the front panel straight out and slide it up until the panel comes loose of the clips.
5.Set the front panel aside and slide the top of the dryer forward.
6.Lift the top of the Maytag electric dryer up,tilting it back and resting it against the wall.
Aug 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Hello I need to get to the belt on my dryer how do i get to it?
Unplug the dryer.
Remove the 2 screws under the lint filter lid.
Remove the lint filter.
Use a putty knife to push in on the 2 clips on the right and left front between the lid and the front panel.
Raise the top lid and move it to the back of the dryer.
Look inside the right and front corners and remove the 2 screws holding the cabinet case to the front panel.
Remove the wires from the door switch.
Pull up and out on the front panel.
You are now in the dryer.
May 24, 2010 | Maytag MED5700TQ Electric Dryer
Cannot open the lid on a maytag dryer (1999 model year, model # MDE6000AYQ) as it doesnt appear to have the plastic little tabs, as some others i have seen done online? as i need to replace the belt....
Here is how to remove the front and the top.
-Open the door, remove the 4 screws, (2 from the hinges and 2 from the open side of the door that are opposite the hinges)
- Pull on the front top of the front panel from both sides it will release and then lift the entire front panel off
- you may be able to get to the belt from here, but if not remove the two screws close to the top that hold the green clips from the front to the top and remove the green clips The top should be free
-lift the door off the frame and set aside.
- you should be able to see how the rest comes apart from there
Apr 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Pop the top off the dryer
Check the door switch. To remove the top there are 2 spring clips or screws located inside door opening going up into the lid. Remove and you will be able to see in side nd check the door switch
Sep 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Heating problem
Unplug the dryer.
Take a putty knife and insert it at the top of the front panel just below the lid and push the 2 clips in.They are about 2 inches in from the right and left sides.
Raise the top lid towards the rear of the machine.
Remove 2 screws on the inside top corners of the front panel. Remove the front panel.
Remove the belt. Remove the drum.
The heater will be on your bottom left.
Apr 12, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
How do i remove the top of my frigidaire dryer to replace parts?
what yo have to do is take a pudy knife and insert it between the top lid and front panel in the front of the unit, you will find a clip on the left side and right side with the knife press the clip in and you can lift the lid after that there is 2 screws at the top and two in front of your lint filter remove them and you are all set
Jan 24, 2009 | LG DLG5932W Gas Dryer
Lifting cover of dryer to fix loose baffle.
Usually their are two sheet metal screws to remove at the top rear of the washer lid/body,,,you must remove these,,,then remove any little brackets(some washers have little brackets which hold the top down) then you should be able to pry the top up with a screw driver,,,pry gently,,,if it will come at all,,it will come,,,but if it feels solid,,check for more points to remove screws.
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Gas Dryer: MDG6000AWW...no heat. We've diconnected the vent...still no heat...I took off the front panel...but don't know what to do from there. My cousin is here...an electrician...but he doesn't...
Sounds like it is the Thermal Fuse. If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel.
But it could be a number of other things too ... like faulty door switch or bad gas igniter...
Take a look at thsi link for your machine ... it provides a number of reasons and some good videos
http://www.appliancepartspros.com/parts-for-maytag-mdg6000aww.html
Helpful?
Good luck on your troubleshooting!
Feb 07, 2018 | Dryers
Dryers Logo
159 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
