Question about NRS OTC 2006 Domestic, Asian and OBDII Smart Cable Super Bundle
2007 VW JETTA Code: P0480 Cooling Fan I Control Circuit Malfunction - The cooling fan stays on high speed after engine is turned off for approximately 45-60 seconds and then turns off. What are typical problems associated with this error code?
Whats causing this issue
Posted on Sep 17, 2012
2 Suggested Answers
SOURCE: 2007 VW JETTA Code: P0480 Cooling Fan I Control
please go to this site and write your experience about this ongoing problem with Volkswagen Jetta cooling fans.
http://www.ripoffreport.com/Auto-Warranty/-Volkswagen-of-Ameri/-Volkswagen-of-America-Poor-C-F95FA.htm
Posted on Oct 14, 2010
What is the connection to a slipping transmission gears & code p0480 on my 2007 VW JETTA?
Because
When is the code detected? The P0480 code is detected when the Powertrain Control Module (PCM) detects that the commanded state of the driver and the actual state of the control circuit do not match.
Read more: https://www.engine-codes.com/p0480.html
P0480 Cooling Fan 1 Control Circuit Malfunction
I have one of these
BUY FIXD FIXD Automotive
Aug 07, 2017 | Cars & Trucks
I have an 05rendezvous,need to locate switches for cooling system,fans aren't co ming on & now I'm going to need a new radiator,cuz plastic broke.But it broke before fans gave out.Which I changed stat
The engine cooling fan system is controlled by the body control module (BCM) and the powertrain control module (PCM) or engine control module (ECM). The BCM performs the calculations as to how long, when and what speed the cooling fans should turn on. The BCM then sends a class 2 message to the PCM/ECM to engage the cooling fan relays. If there is a malfunction with the BCM, the PCM/ECM will control the engine cooling fans independently. The engine cooling system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM/ECM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan 2 relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 3 or S/P relay and the cooling fan 2 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The BCM and PCM/ECM command Low Speed Fans on under the following conditions:
Engine coolant temperature exceeds approximately 106?°C (223?°F).
A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The BCM and PCM/ECM command High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
When certain DTCs set.
The three relays are located in the under hood fuse / relay box ! You need to have it checked for DTC'S -diagnostic trouble codes ! An you need a GM Tech 2 scan tool !
This diagnostic procedure supports the following DTCs:
DTC P0480 Cooling Fan 1 Relay Control Circuit
DTC P0481 Cooling Fan 2 and 3 or S/P Relay Control Circuit
DTC P0691 Cooling Fan 1 Relay Control Circuit Low Voltage
DTC P0692 Cooling Fan 1 Relay Control Circuit High Voltage
DTC P0693 Cooling Fan 2 and 3 or S/P Relay Control Circuit Low Voltage
DTC P0694 Cooling Fan 2 and 3 or S/P Relay Control Circuit High Voltage
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, command the Fans Low Speed ON and OFF.
Do the low speed engine cooling fans turn ON and OFF with each command?
Go to Step 3
Go to Step 4
Important:: A 3 second delay occurs before the powertrain control module (PCM)/engine control module (ECM) changes the cooling fan speed.
With a scan tool, command the Fans High Speed ON and OFF.
Do the high speed engine cooling fans turn ON and OFF with each command?
Aug 08, 2015 | Cars & Trucks
I have a 2002 Dodge Intrepid with a code of odb480
This is a generic powertrain diagnostic trouble code (DTC), which means it covers all makes/models, 1996-newer. However, specific troubleshooting steps will vary depending your vehicle. pulling the code P0480 displayed, if refers to the engine cooling fan circuit. It is a generic code applying to all OBD II (on board diagnostics) vehicles. The PCM (powertrain control module) senses the increase in engine temperature through the CTS (coolant temperature sensor) located near the thermostat. When the temperature reaches about 223-degrees F (value depends on make/model/engine), the PCM will command the cooling fan relay to turn on the fan. It does so by supplying the ground to the relay.
There is a problem within this circuit causing the fan to fail to operate allowing the engine to overheat while sitting still or driving at a slow speed. When the PCM attempts to activate the fan and senses the command and the result do not match, the code is set. Symptoms may include:
  • Check engine light (malfunction indicator lamp) illumination and code P0480 set
  • Engine temperature will rise when the vehicle stops and idles
Potential Causes The causes for this DTC may include:
  • Faulty fan control relay 1
  • Fan control relay harness is open or shorted
  • Circuit electrical connections poor
  • Faulty cooling fan 1
  • Faulty coolant temperature sensor
  • Fan cooling fan harness is open or shorted
  • Cooling fan circuit poor electrical connection. hope this helps you.
Oct 12, 2014 | 2002 Dodge Intrepid
Passat code P0480
P0480 VOLKSWAGEN - Cooling Fan 1 Control Circuit Malfunction
Possible causes- Fan control relay harness is open or shorted
- Fan control relay circuit poor electrical connection
- Fan cooling fan harness is open or shorted
- Fan cooling fan circuit poor electrical connection
- Faulty fan control relay
- Faulty cooling fan 1
- Faulty ECM (very unlikely)
Apr 11, 2012 | 2007 Volkswagen Passat Sedan
Diagnostic code for my 2007 saturn ion says p0480 cooling fan 1 control circuit malfunction. what does this mean.
WHAT IT MEANS YOUR FAN CONTROL RELAY CONTROL CIRCUIT IS OPEN OR SHORTED TO GROUND. FAN CONTROL RELAY CONTROL CIRCUIT IS SHORTED TO SYSTEM POWER. THE FAN CONTROL RELAY POWER CIRCUIT IS OPEN CHECK COOL FAN 1 FUSE. FAN CONTROL RELAY IS DAMAGED OR HAS FAILED. PCM HAS FAILED.I LISTED ALL POSSIBLE CAUSES TO CODE PO480.
Jul 05, 2011 | Saturn Ion Cars & Trucks
Check engine light - dignostic code P0480
P0480 Cooling Fan I Control Circuit Malfunction, check the fan fuse and Replace the malfunctioning fan control relay 1 - Replaced cooling fan 1
Jun 23, 2011 | Chevrolet Monte Carlo Cars & Trucks
When should both coolant fans turn on? 2005 vw jetta
The fan may not be the problem. It could be a few things not turning the fan on. It is hard to say how much this is going to cost. The error code that you have P0480 is Cooling Fan 1 Control Circuit Malfunction. So some component in that circuit is causing the fan to not come on. I hope this helps you.
Aug 19, 2009 | 2005 Volkswagen Jetta
Check engine light error code 480
Chrysler has issued a TSB (#18-004-07)containing the fix for an inoperative cooling fan on 2005-06 Caravans and Town & Country vans with the 3.3L or 3.8L engines. The problem usually occurs after driving in heavy snow conditions where snow and ice form at the bottom of the fan shroud and block the fan blade. This condition also sets a P0480 code in the PCM. The fix requires a PCM reflash. If you have an inoperative cooling fan or a P0480 code, check the version label attached to the PCM. If a software update has not been performed since this TSB’s issue date of January 24, 2007, you should have the update performed before you start replacing any parts.
Dec 13, 2008 | 2005 Dodge Caravan
NRS OTC  2006 Domestic, Asian and OBDII Smart Cable Super Bundle Logo
960 people viewed this question
Top NRS Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a NRS Electrical Supply Expert? Answer questions, earn points and help others
