Question about GE 5 cu. ft. / 142 liter Chest Freezer FCM5DMWH
Leaking chest frezzer model #fcm5dmcwh - GE 5 cu. ft. / 142 liter Chest Freezer FCM5DMWH
  • 3 Answers
Dc518 wey will not freeze top was cool but not now what can i do takes r134-a
Check the condenser is clean. If the outside of the chest isn't warm and you can hear the compressor running. It's short of gas.
May 04, 2012 | Danby Freezers
Crosley chest frezzer
as I said in your other pose the the hinge part number is 297322000
Mar 22, 2012 | Crosley Freezers
I need an online manual for proline freezer CF6 37P see drection for temperture control
there a alarme light showing on my chest frezzer what dose it mean
Aug 02, 2011 | General Freezers
Chest freezer model mfco5mobw4 been plugg in for 2 days now set on the coldest setting not getting cold compressor is warm
God day,
Either the refrigerant has leaked out or the compressor isn't pumping properly. If you can put your ear up to the unit and it hums that is the compressor running.
No practical repair possible unless the unit is under 5 years of age in which case you are entitled to factory warranty service.
Apr 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
May 02, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
My fridge freezer defrosted n now wont wrk
what you are hearing is the overload kicking in and out. which means bad start relay /bad capacitor/low voltage/bad overload/bad compressor.you can buy a 3in1 to eliminate all but the compressor. and the voltage check them first.
Dec 14, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Danby freezer leaking water
there is a line from the freezer defrost pan to the evaporation pan at the bottom. They often get clogged with bugs, dirt,etcWhen that happens, the defrost pan overflows resulting with a spill of water. Find it, blow it free , and you should be OK.good luck, John
Nov 05, 2008 | Danby 5.5 cu. ft. / 156 liter Chest...
Chest Freezer not cooling
Please don't rate this solution, as anything but FixYa brings my rating down, but here's what you've got:
You have a refrigerant leak (commonly referred to a Freon, but these days usually R134A refrigerant). Some refrigerant has leaked, so you are still getting some cooling, but there is not enough refrigerant left to cool throughout the entire evaporator coils. This is NOT a repairable condition, as the coils are foamed in place and not accessable for leak repair. If this unit is under 5 years old (typical sealed system warranty) the manufacturer will most likely replace your freezer with a new one. If over 5 years, you are out of luck. Buy a replacement freezer.
Oct 12, 2008 | Whirlpool 10 cu. ft. / 283 liter Chest...
Frost free frezzer
The drain is probably clogged. Use a pipe cleaner to clear and then use a turkey baster and force hot water through. Follow with a weak bleach solution. Drain is usually in the middle of the bottom. maybe towards the back. It is supposed to drain into a pan underneath the unit and then evaporate. Another solution could be a leaky door gasket. This overwhelms the defrost system and causes leaks.
Jun 16, 2008 | Frigidaire Freezer GLRT183TD
GE 5 cu. ft. / 142 liter Chest Freezer FCM5DMWH Logo
323 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
