Question about GE Refrigerators
GE refrigerator Model No. GBS22KBSAWW A relay on the control board was clicking and the evaporator fan would try to start with each click. With the evaporator fan disconected the compressor runs, etc. I replaced the evaporator fan motor, and before I installed it, I pluged it in and the motor turned, but when I put the fan blade on, it would not turn, like the old one. Also, the condensor fan does not turn, but does not make the control board click.
  • Paul Luckey Sep 09, 2010
    When the evaporator fan motor is running without the fan blade attached, the compressor runs without a problem. The clicking of the control board only happens when the evaporator fan motor is connected to the system AND the fan blade is in place. Also the condensor fan motor does NOT run at any time, but does not cause the contol board to click. This clicking of the control board happens about once every second.
  • Paul Luckey Sep 11, 2010
    I have replaced the control board AND the evaporator fan, and all is running smothly. I didn't check the resistance of the fan motor, since I had replaced that before asking this question. Your 2nd comment was much more clear and on target. Thanks!! Ray
  • 2,272 Answers
This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. The Relay needs to be replaced and checked.But if the problem is same then the control board is causing this problem. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 08, 2010
  • raj somaiya
    raj somaiya Sep 09, 2010
    Its a control board fault.
    Because the fan is controlled by the controlled board.
    The control board regulates the fan speed, and the noise is caused by the board setting the fan speed (incorrectly) to just the right pitch.
    the main control board is faulty which could cause the fan to run at the wrong speed and generate the annoying clicking noise.
    This problem is faced by many others too.The control board gets faulty causing this clicking noise.
    Thanks for keeping updated with your query.
  • 11,896 Answers
If it turns without the fan blade but not with the fan blade, the motor is likely weak and will need to be replaced. You can test it with an ohmmeter on each wire connection and see if you get a good strong reading or a low bad one.
Posted on Sep 09, 2010
  • Nate Stansfield
    Nate Stansfield Sep 13, 2010
    If the compressor runs without the fan and fan doesn't run while plugged in, then I would test the fan like I had stated earlier. You can test the resistance with an ohmmeter on the Rx1 setting.
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
Psc25mstass The refrigerator does not cool at all. condensor and evaporator fans run but the compressor does not. When plugged in you can hear the inverter whine then the compressor will turn over and...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 16, 2011 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I have a GE profile side by side model PSS26SGRCSS. Lately the water and ice dispenser have worked only intermittently with a dimming of the lights. Tonight it stopped working and the temperature display...
Something has malfunctioned on *********** control board part number WR55X10942 This board controls most functions of the refrigerator. It would be simple to say change the board but this is the first time I have seen one affect so many different controls that I recommend that a service technician come out and make sure that something other that that board is not affecting the other controls on your refrigerator. Please let me know what the technician finds, Thanks, Sea Breeze
Sep 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Jul 26, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
