Question about Microwave Ovens
According to technican the oven registers 15 degrees above the setting and drops down 40 degrees between going off and coming back up Example, set oven for 350 degrees and it goes up to 365 before it cuts off and then drops down 40 degrees He saysa that this is the way Frigidaire works, is this correct. I have trouble with food not turning our correctly. Tried making sweet potato biscuits, baked at 425 degrees for 12 minutes, prodict did not brown and tasted doughy. This should not be.
  • Microwave Ovens Master
  • 9,085 Answers
There will be some hysteresis.
If the owner's manual does not specify how much, I would contact Frigidaire customer service.
See http://www.frigidaire.com/manuals & http://www.frigidaire.com/contactus
Posted on Sep 08, 2010
Is the sharp above range microwave model r-1871t recirculating?
According to the Sharp product site, http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models/R1871.aspx , the R-1871 is a convection and microwave oven. The manual describes using the convection oven feature on page 18 (page 20 of the PDF). The direct link to the manual is: http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R1872.pdf . The convection button is on the top left in the middle group of buttons. You use the numeric power level buttons to set the oven temperature. When you program convection cooking, the 1 button will bring the oven to 100 degrees F. The 6 button gets the oven to 350 degrees F.
I hope this helps.
Sep 18, 2015 | Sharp Microwave Ovens
How to make rice
Cover with the lid and turn the heat down to its lowest setting. Leave it alone - once the lid is on, set the timer and go away! If you lift the lid and let the steam out you can slow down the cooking process, and rice should always be cooked as briefly as possible. Give white rice 15 minutes and brown rice 40 and use a timer - overcooking is what spoils rice. The best way to test if it is cooked is simply to bite a grain. Another way is to tilt the pan and, if liquid collects at the edge, it will need a couple more minutes' cooking.
May 31, 2014 | Emerson Microwave Ovens
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
GE JVM1790WK convection microwave
I assume you've referred to your owner's manual to be sure you are operating the convection properly?
If for some reason you don't still have your owner's manual, you can get it here. See the tips on page page 30.
You can also do a hard reset by unplugging the oven for a couple of minutes, plugging it back in, then setting the clock and trying again.
If it's still not working, you may have a bad sensor or other problem.
Sep 04, 2012 | GE JE1590 Convection / Microwave Oven
How to defrost solid frozen thick steak
you can set your microwave to defrost or 50% power to defrost steak
if this was helpful please give it a thumbs up to help others too
May 19, 2011 | Microwave Ovens
According to one of your solutions rergarding a noisy k45 kitchenaid I removed the brushes to examine and upon multiple attempts to reinsert properly - the noisy machine no longer operates to make noise. ...
Hello; Bummer trade off, huh? Ok , here we go.Getting it to run again, then address the noise. The attached drawing shows how the brushes should be installed. The brushes take a set and must be placed back into the same holder and leading edge into rotation, set square on the armature, w/full contactand spring pressure. After Slidingthe brush in place, lift it slightly and let it drop back onto thr srmature. Not much and let the spring set the brush and align .You want to make sure the brush moves smoothly up and down. The part the brushes ride on is called the the commutator. The copper bars. Each is separated by a thin piece of mica. If there is any copper bridging the mic, the motor will be noisy and not run smooth. In this case, use an ice pick to scratch the mica so it's below the copper ba abou, never mind, just run the pick down the mica groove to keep the bars seperated. Put it all together and turn it on. You may have to tap the motor to get it going. Once it gets going let the motor run for about 15 minutes at high speed and 5 minutes at low speed, Good luck and take caution not to get shocked. I'm here so feel free to keep in touch. 909-630-3192. Ned
Apr 16, 2011 | Microwave Ovens
MY OVEN IS VIKING OVEN CAN YOU PLEASE TELL ME HOW TO CHANGE FARENHEIT FROM CELCIUS
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
Mar 22, 2011 | Microwave Ovens
How to set the clock on my sharp carousel microwave
Touch STOP/CLEAR pad.
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
Sep 25, 2009 | Sharp Microwave Ovens
The oven will turn on and get warm (not up to set temp)not as hot as it should. I no longer hear the forced air noise from the fan/blower from the back of the oven? It will not cook food, in the time frame...
is your power setting up allthe way (10) is it a convection oven also? microwaves dont usualy have a temp. setting unless there is a probe pluged in inside oven to a jack on inside wall of microwave microwaves can also get old and lose power if so you can get cheep ones at wallmart
Jun 17, 2009 | Microwave Ovens
Need help with installation
Your Spacemaker 1400 should be model number JVM1640SJ (or something close to that). If so, go to managemyhome.com and register. This is a FREE service. Once registered, log in and click on the "Home Manager" section at the top of the page. Look for the "Owner's Manuals" link on the drop down menu. Both, your Owner's and Installation Manuals are available in a downloadable .pdf format. All you need is Adobe Acrobat installed on your computer to be able to view it. I hope this helps you.
Apr 23, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
