Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
My water dispenser will not cut off every time when i remove the glass. How do i fix it? mdl # msd2754gr.
Inside water dispenser pumps water out really slowly on GE Profile PFS22MISBBB
It is possible that your water filters are getting plugged. Have you changed any filters lately?
The meat pan lever may also be turned to the coldest position and on units that have a low water usage, this will also cause the tank to freeze. You will want to lower the meat drawer setting or use more water from the door. This does not apply to Top Mount water dispenser models, because they do not have a reservoir. Problem requiring service, glass fill time.
View a short video about troubleshooting water dispenser issues :
Play Video
View a short video about slow water dispensing issues:
Play Video
  • Dispenser drips water constantly will be a water valve problem, and should be checked by a service technician. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
  • Dribble as defined as a small amount of water (few drops) that may miss the glass ONLY AFTER USAGE. This is due to a delay in the overall system.
    Dribble can be minimized by the following actions:
    - Purge the tank, by holding down the dispenser for 2 to 3 minutes, to remove any trapped air that may be building pressure and causing the dribble.
    - A few drops is normal, but you can also prevent water from missing the glass and dripping down the cradle area by moving glass slower when removing it from the cradle.
    - You may need to periodically empty the recess grill and clean out underneath it to prevent overfilling and water dripping down the front of the refrigerator.
  • Also, remember the dispenser in the door will not operate unless the door is closed
  • Apr 10, 2012 | GE Refrigerators
    Water dispenser works, ice maker makes ice but doe not dispense
    Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
    Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
    Ice & water dispenser get stuck, water & is keep coming out os dispenser even after you remove glass
    Unplug unit
    Remover dispensor housing. Careful not to break tabs.
    You will see the white plastic actuator arm.
    Follow the arm to where it becomes part of the main support.
    Push the arm you will see where the main support is catching on a plastic *** on the rear housing.
    Cut or file off part of the ***. so it wont catch.
    Reassemble dispensor.
    Jan 18, 2010 | LG LSC26905TT Side by Side Refrigerator
    Maytag model # MSD2754GR the refrigerator leaks
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
    Good Luck,
    Gilsh
    Nov 30, 2009 | Heating & Cooling
    Maytag MSD2754GR - Ice Maker quit working.
    Is the freezer cold enough? Should be close to 10 degrees.
    Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
    If it does dump the ice but don’t refill with water.
    Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    Aug 29, 2009 | Maytag MSD2456G Side by Side Refrigerator
    Model MSD2754GR Side-by-side.. it will dispense water but will not fill the ice trays (I have checked all the obvious stuff, water supply lines and ice sensor arm). Don't here the control module "clicking"...
    Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
    Aug 11, 2009 | Refrigerators
    Water dispenser not working
    The filter you installed was empty, You will need to purge the air from the system. Simply hold a glass in the dispenser with water selected until water flows.
    Please take the time to give this solution a fix ya rating
    clarkco
    Feb 16, 2009 | Amana ARS2464B Side by Side Refrigerator
    TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
    I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
    Not sure if this is the same problem with your unit, but sounds the same.
    Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
    Replacing water fitting assembly
    water dispenser continues to run too long after removing glass
    Oct 23, 2008 | Refrigerators
    Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water Logo
    24 people viewed this question
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    Shehu Pro
    Shehu Pro
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
