Question about Brother HE-120 Sewing Machine
Model HE-120 was sewing 2 pieces of naugahyde w/ heavy duty leather needle when needle started to ****-got "The safety device has been activated." error message. No tangled threads found. Balance wheel will move 1/4 turn either way. Both belts ok. Any ideas as to why it won't sew anymore?
    Genius:
  • 1,788 Answers
Go to brother-usa.com website and try calling support for free.
Posted on Sep 08, 2010
I have a Singer sewing machine#7258 what setting and needle and thread do I use to sew leather
Hope it is light weight leather. It should not be used on heavy leather.
Use a brand new heavy needle (leather). Avoid using upholstery or thicker thread as that sometimes does not feed well through the needle eye. Set it for a longer stitch. And you might want to adjust the presser foot pressure to accommodate the thicker fabric under the presser foot. Also, a leather foot, roller foot, or walking foot may be helpful--if if not available, try using parchment paper (or something similar) on the surface of the leather to help it slide under the presser foot..
Jan 06, 2018 | Singer Sewing Machines
What type of needle do i need to sew heavy duty canvas on the 29k58 model
I buy a number 16 for blue jeans and they sew drapes and heavy waterproof material I made some covers for the chairs outside. If you get them at fabricland or JoAnnes they will be able to guide you in case something better is now available. good luck
Sep 25, 2017 | Sewing Machines
Have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather foot do I need?foot do I...
hi there
regarding your inquiry about JUKI machine model DDL-8700 , first your machine type was what ? DDL-8700/SS ( for light to medium material , DDL-8700/HS ( for jeans and can use to sew light to medium lather, type of needle is DBx1, size for lather was 18 and you can use thread number #30 and #20. one more thing you want to change your presser foot to teflon presser foot ( please see attached photo for that presser foot you want to buy.
if need more information please ask
thanks and best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Mar 07, 2015 | Juki DDL-8700
I have a consew sewing machine model 260 what is the use?
Heavy duty fabric sewing....canvas for tents and awnings, leather maybe, upholstery fabrics.....
Feb 07, 2015 | Consew Sewing Machines
Needle stopped penetrating my fabric
you need to replace the needle again, is the needle the right one for the heavy fabric?
Dec 10, 2014 | Sewing Machines
I am sewing leather with bernina. Got proper leather middle but the needle either gets stuck or falls out. Why and what should I get that I can work with heavy leather ( FYI I am not working with heavy at...
check the needle holder if its tight enough not to fall out. now if your needle gets stuck, try using another needle appropriate for your material. if your problem persists, the problem might be on how do you attach your needle. try attaching in reverse side.
Jul 14, 2014 | Sewing Machines
Turn the machine off. Check for a broken or bent needle or a bird's nest in the bobbin area. Sometimes when I try to put an extra heavy piece through the machine I' ll get that message. The most common reason for the error is a broken or bent needle.
Jul 02, 2014 | Baby Lock Espire
I have a singer 201k sews fabric perfectly but I wanted to do some leather I bought a walking foot attachment leather needles and heavy duty thread but the machine is not stitching properly very tiny...
Sounds like it is still not feeding smoothly, Try putting some clear tape on the bottom of the foot and tissue paper under the leather. Leather is tricky sometimes.
May 31, 2014 | Singer Sewing Machines
I am sewing outdoor fabric and using the strong thread and having problems with the bottom thread (bobbin), it is loose and sewing right. I have tried tightening the tension on the bobbin. It was sewing...
Probably a little heavy duty for a domestic machine - most don't like thread through the bobbin tension device any heavier than 50 grade.
Some tension devices have a hole that you can use to bypass the tension spring (Elna is one) which allows thread like perle cotton to be used in the bobbin. But you still can't put it through the needle (just on the underside for decorative sewing effects) .
In the past I've needed to sew vinyl tractor seats where I was stitching the vinyl to a 1/4" thick foam and after trying everything (roller foot, leather needle) on the domestic machine, I bought a Singer 20U industrial machine with 1 1/2 hp motor in a table in order to seam this weight of textile. Different system needle used and the bobbin could handle heavier weight thread.
Probably not the response you wanted though.
May 02, 2011 | Baby Lock Imagine
Machine skipps stiches whats wrong
You need a heavy duty needle #16 or #18 to sew leather and teflon presser foot is helpful
Apr 15, 2010 | Singer 7442 Mechanical Sewing Machine
Brother HE-120 Sewing Machine Logo
147 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
