Question about Brother SX-4000 Typewriter
Trouble installing correction tape - Brother SX-4000 Typewriter
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support you will find a manual there.
DICKYO
Posted on Sep 09, 2010
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
The correction tape isn't working. it's installed properly, i think, but it doesn't erase anything.
Try taking the tape out and re-installing with the "dull" side towards the paper...if that doesn't work try a new correction tape.
May 29, 2009 | Olympia Mastertype 3 Typewriter
Installing kenwood cd player in EF ford falcon
this is not a sales pitch but i purchased the correct patch harnass from pmr, it should be available at any good sterio store for about $10
Mar 17, 2009 | Kenwood KDC-MP4028 CD Player
Changing correction tape
i have the same problem. can't find a manual anywhere. someone please help
Mar 10, 2009 | Brother ML-100 Typewriter
Daisy wheel not moving
Be sure the correction tape is dry type, if it is a sticky one it will cause you all kinds of trouble.
DickyO
Jan 31, 2009 | Brother SX-4000 Typewriter
Installing correction tape
The full spool goes on the L. side of the printer it goes thru guides on both sides of the printer and thr empty goes on the R.
Be sure the dull side of the tape faces the paper.
DickyO
Aug 28, 2008 | Brother ML-100 Typewriter
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
try to see it in the sides or it might be in the bottom of the machine in some models remove the older and replace the newer.
Aug 25, 2008 | Brother SX-4000 Typewriter
HAVING TROUBLE PUTING IN THE CORRECTION TAPE
Make sure you are installing the tape with the sticky side facing the paper. I
May 05, 2008 | Brother ML-100 Typewriter
Changing correction tape on swintec 2600
Be sure the corr. tape not a tacky kind, then type some thing and correct it watching the mechinism th see which one turns and in what direction. Install the empty spool on that hub thread the L/O thru the guides with dull side facing the paper and then the full on the supply hub. there may be two or more guides depending on the printer.
Hope this helps
DickyO
Apr 28, 2008 | Office Equipment & Supplies
Installing the correction tape
BrotherUSA.com has a free manual download.
Aug 20, 2007 | Brother GX-6750 Typewriter
Brother SX-4000 Typewriter Logo
220 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
