There are several things you can do to help limit motor noise interference but first you have to figure out if the noise is coming from the power wire, or the antenna system. Here is how to do that.
If the noise goes away when you unplug the coax, the noise is getting in from the antenna system. It's either getting in from bad coax, poorly grounded antenna, or position of antenna. For instance, if its mounted on the back of the truck some times it picks up the fuel pump noise.
If the noise is still there then it is coming in via the power cable. If this is the case then there are a few things you can do.
First. Make sure the radio has a good ground. Next, run the power wire right to the battery. This eliminates most noise. Twisting the power cord helps cancel out some noise. And a knot right at the plug end of the cord also helps. Lastly, if the noise is still bad you can get a power wire ground loop noise canceling unit. This stops most noise.
