Question about AO Smith 1.5hp Pool Pump Motor 2 Speed Ao Smith Electric for Motor Pool & Spa Pump Bn34
Pump has been starting well then notice hours later no circulation. Now motor runs and there is no circulation from the start. Checked for air in system and had pump primed. Will not pick up suction.
    President:
  • AO Smith Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Open up the pump and make sure the impeller is not broken. If it is ok you will need to look for leaks in the suction line(s). Start with the pump skimmer basket lid gasket and any unions or valves in front of the pump. You may need a pressure test if you can not find the suction leak on your own. Plumbers and some pool service companies should be able to provide that service if you need it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 08, 2010
Why the intex pool 2500 pump stops water flow after 3 hours
bad pump motor replace pump its overheating
Jun 23, 2014 | Intex Pool & Spa
Starts dies
Your fuel pump or fuel pump relay may be getting hot. And tap on the MAF/MASS sensor with engine running and see if that affects the engine even the slightest while it is running.
Jan 06, 2014 | Land Rover Cars & Trucks
I have a 1997 Taurus. Last Saturday I had my battery terminals cleaned and my cables were striped back and rethreaded. My car would not start but the battery was fine. When everything was reconnect
My assumption as when you say "good an strong" is that the motor is turning over. If you are confident it is getting fuel then there are only two other ingredients - Air and spark. You could check the air filter for air quality as this is usually a simple step but it is more likely that you are missing ignition (spark) - start with checking that your ignition coil / coils are working .
Jan 23, 2013 | 1997 Ford Taurus
I have a Polaris PB4 booster pump, installed late July 2006, vacuum was running for an hour tonight but I noticed it wasn't moving across bottom of pool normally--wheel was skipping. I shut things down...
The click is the internal thermal overload. Since the pump wouldn't start it overloaded and opened the circuit. Either there is something jammed in the impelller locking the pump up or you have a motor problem. IF it a capacitor start motor, you could have a bad capacitor. Or if it has a starting switch it may not be operating. Start off and be sure the motor turns freely. If you replace capacitor be sure it is same voltage and MFD as the old.Check all wiring connections.
Aug 18, 2010 | Polaris Pb4 - 60 Booster Pump
Light is on, motor is running but no hot water circulating. have taken it apart and cleaned per instructions, too. any suggestions?
is the outer casing hot after a short time it may be the capacitior some of the units have a venting nut which may need to be opened to release air in the pump but also allow the shaft to be rotated and started if it not air locked or faulty capacitor the in/out valves need to be checked.
Aug 16, 2009 | Grundfos Plumbing
Intex pool filter/ pump just stopped working
Try giving your pump more air circulation.
Turn off pump when not around it.(should only need to run for around 3 - 4 hours on a small (kid) pool 6 - 8 hours for standard house pool
You could put you pump on a timmer - set shut off time to just before you pump shuts down.
Check you pump (when not conected to mains power) - get some WD40 into it - (salt and metal no like each other)
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
AO Smith 1.5hp Pool Pump Motor 2 Speed Ao Smith Electric for Motor Pool & Spa Pump Bn34 Logo
96 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
