Question about Jet 3 Ultra Power Chair
I charge my jet 3 ultra with the cord but as soon as i remove the cord it dies what do I do? I no longer have the instruction manual
  • 692 Answers
Jaeger How long have you had the chair? And have you changed the batteries or had them changed within the last year? The problem could be the batteries. If the were run down or not charged for a long time then your charger cannot pick them up enough to reach a full charge or in your case no charge at all. Now if the batteries are fairly new but have run down the problem could be the charger. If you have a digital voltmeter and your Jazzy has an on-board charger -- plug in the charger then put the test leads in the charger port two outter plug holes under the front of the joystick set the meter to 200 volts dc. You should read up to 30 volts with the charger plugged in. Now unplug the charger and you will read the battery voltage it should read 24-27 volts. If when you have the charger plugged in and you don't read up to 30 volts then the charger is bad If after charging overnite and you don't read 24-27 volts the the batteries are bad If Medicare purchased your chair then you can call a service company to repair your chair and they will bill Medicare for the cost of the repair. Medicare will pay 80% of the cost. You can call Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have a tech come out and rpair your chair. Hope this helps you
Posted on Sep 09, 2010
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
On ultra jet 3 there is a 3 prong outlet below the seat on the right & has cord that goes to normal outlet is that how to charge it
Jet 3 Ultra www.pridemobility.com 33
VI. BATTERIES AND CHARGING
To charge the batteries using the off-board charger:
1. Position the front of your power chair next to a standard
electrical outlet.
2. Be certain the controller power is turned off and the
freewheel levers are in the engaged position. See III.
"Your Power Chair."
3. Plug the off-board charger into the off-board charger/
programming socket on the controller.
See figure 25.
4. Plug the off-board charger into the electrical outlet
You should use the charger supplied with the power chair. It is
the safest, most efficient tool to charge the batter-ies. We do not recommend using other types of
chargers (e.g., an automotive battery charger).
Sep 07, 2014 | Health & Beauty
How do I know if my jet 3 ultra is charging? I just bought a used one today and do not have a manual
The chair should have a meter on the rear panel where the 9 pin connector for the joystick plugs into the chair when you plug in the charger cord the meter should move up and the lights on the joystick should flash indicating the charger is plugged in. When the chair is fully charged the meter should read zero or bounce up and down. Hope this helps
Feb 02, 2011 | Jet 3 Ultra Power Chair
My battery is going low how can i charge it or how do i know what model to replace it with?
well theres a cord that comes with your chair ,it looks like the cable you would plug into your computer and is almost the same.That cord is what you will be charging your chair with..the jet 3 also takes two 12volt battery's which in some cases are called u1 gel cell battery.
hope i was helpful
Jan 21, 2011 | Jet 3 Ultra Power Chair
We have been given a Jet 3 ultra motorized wheelchair and have lost the offboard charger. I have looked online and can find only on-board charging cords. What do I look for to find a new power cord?
The power cord you are looking for is just about the same as your power cord plugged into your computer,you can find on just like it at your local radio shack or office depot . Have a good day hope I was able to help.
Jan 03, 2011 | Jet 3 Ultra Power Chair
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
JET 3 POWER CHAIR SEAT REMOVAL
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
Mar 30, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
104 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
