Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
Bissell pro heater 2x won't spray - Bissell 9400 ProHeat Upright Wet/Dry Vacuum
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 08, 2010
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
  • 17 Answers
SOURCE: my bissell pro heat 2x will not spray water to
Here is the fix
Posted on Feb 08, 2010
SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Posted on Jun 25, 2008
  • 5 Answers
SOURCE: bissel pro heat 2x wont spray any water
turn custom dial(heavy traffic, normal clean...etc) to water rinse, fill formula container in back so if you want to use cleaners you change the dial. hope that helps
Posted on Feb 19, 2009
SOURCE: bissell pro heat - belts are ok. water will not
Remove the handle, disassemble the lower section of the top to get to the heater. Make sure the unit is unplugged! Use miniature bottle brushes like the painters use to clean paint sprayers (I purchased mine from Harbor Freight for about $4) and clean out the ports. Also check the valve that the trigger opens. It is located just above the heater.
Posted on Feb 17, 2010
Testimonial: "Thanks for the advice. Sure enough, one of the hose ports was clogged. This saved me at least $85. "
Hi my Bissell pro heat 2x the brushes don't turn and nothing come out like the water what to do
Bissell 2X machines are famous for this. The brushes not turning is probably just a broken belt but the not spraying is a bad solenoid. I've never seen a 2X that didn't fail after about 6- 8 uses
Jul 02, 2017 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell pro heat 2X pet will not spray water.
Bissell 2X machines all seem to do this after 4 or 5 uses. It's a bad solenoid. Most vac shops won't touch the 2X with a 10 foot pole. Get a Hoover 5914 and stay problem free.
Oct 18, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell pro heat 2x 9200 won't put out water HELP!!!
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Vacuums
I have a bissell pro heat 2x +and the water is not coming out of the hand tool or the carpet cleanerr
We are sorry about the issues you've run into.
This link gives detailed troubleshooting instructions for you: http://www.bissell.com/FAQDetail.aspx?id=1122&icid=ccrr
And this video shows easy maintenance items: http://www.bissell.com/how-to-videos/proheat-2x-machine/care/?icid=ccrr
If your machine continues to not spray, please take it to a BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties other than no spray, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
One pointer that can help between uses is running water through the lines. First, put clean water in both tanks and set your unit to the heavy traffic setting for one pass. This will flush out any cleaning formula in the lines so your spray tips won't get build-up between uses, which can lead to a lack of dispensing the cleaning formula.
Jun 27, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
bvnvn
Jul 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel carpet cleaer does no spray or **** up water
Need model #, but if unit is NOT a pro 2X then see following repair. If the unit does not spray from nozzle but DOES spray from upholstery hose, then the heater is likely clogged and the upper handle must be disassembled and heater removed and replaced. If the spray doesn't come out from either place, then check belts. If belts are o.k. you need to disassemble base and likely replace pump. pump replacement is a little tricky.
J G
Oct 29, 2008 | Bissell Vacuums
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
1,069 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
