Question about Braun 4501 Electric Shaver
Shaver has no power, plugging in does no good. Maybe needs new battery? How to do that
  • Braun Master
  • 1,610 Answers
You will find compatible battery for model 4501 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
to open the shaver you will need to remove the two round screw covers on the bottom. Then remove the screws underneath. Next, remomve the foil and cutters and then remove the swivel frame be taking out the tiny screw on each side. Pay attention to which way the swivel frame goes on.
You can now seperate the front and back by gently prying apart at the bottom. Inside you will be able to lift out the circuit board. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs.
Reassemble in reverse order
Posted on Sep 09, 2010
How to replace battery in braun 5720
Braun Select Models Electric Shaver Disassembly Tutorial
1. Remove two screws on the bottom, where the power plugs in. Need to remove two ribber plugs first.
2. Pull from shaver head and remove shaver "guts" from case. (It will be hard to remove as it is encased in rubber to make it waterproof, but keep wiggling and tugging)
3. Remove old batteries and replace with new ones.
4. Re-assembly is reverse
Nov 08, 2013 | Braun 360° Complete 8985 Electric Shaver
Shaver won't run without cord plugged in and has no power to shave
Symptom would suggest batteries need replaced.
You will find compatible batteries at shaveroutlet.com. You will need two. See link below. http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the page for a helpful disassebly video.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Feb 20, 2011 | Braun Syncro 7526 Electric Shaver
I have a brand new remington r 9500 r rotary shaver which does not get charged when its adaptor is plugged into an wall power outlet. Please advise me to make this shaver do its job. Returning the item may...
Model R-9500 has been discontinued for several years. It is very possible that the batteries are dead because they are so old. You may need to replace them. You will find the correct battery type at shaveroutlet.com. See link below. You will need 2
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To change batteries, remove three screws on back. The third screw is hard to see. To access it, you will need to remove the trimmer from the point that it pivots out from the shaver. Use a small flat screwdriver to gently pry the small plastic pegs from their corresponding sockets on the shaver body. Remove back cover. Inside, remove the metal clip that covers the batteries near the bottom of the shaver. Unsolder the batteries from the wires. Solder in the new batteries.
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 30, 2010 | Remington Titanium SmartSystem R-9500...
Anyone know HOW to change the battery on the Remington Titanium R-950 shaver? Also, I am not sure if the battery is no good or the power cord is no good. Any one have any experience with this shaver?...
It is doubtful that the cord is the problem unless there is visable damage to the cord. Most likely, the batteries are dead. You will find the correct replacement battery type at shaveroutlet.com. See link below. You will need 2
To change them, take off the back cover by removing the screws. Inside you will see the two batteries. There may be some black tape on the ends. If so remove the tape so that you can get to the tabs on the batteries. Unsolder the old batteries from the wires and solder in the new batteries
If you are not equipped to do this yourself, shaveroutlet.com can do it for you. See link below for information and ordering
Dec 04, 2010 | Remington Titanium Microflex R-950...
One morning the shaver was hot to the touch (I leave it plugged in because the batterys won't hold power) and it hasn't worked since. Will new batterys fix the shaver?
If the old batteries haven't corroded and ruined the inside of the shaver, you should be able to fix it with just changing the batteries. You will find batteries for model 3805XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To open the shaver, you will need to remove the 4 screws on the back and remove the back cover. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Feb 22, 2010 | Norelco 3805 XL Electric Shaver
I own a Braun Electric Shaver Model 6525 Flex Ultra Speed. I plug it in and nothing! I am pretty sure the rechargeable battery needs replacing and I don't know how to open the razor to replace it. Also the...
if the shaver is DEAD and the green light no longer illuminates when you plug it in, the circuit board is almost certainly bad. The circuit board will burn out if you run the shaver from the batteries for a long time after the batteries have stopped charing properly.
you can purchase a new circuit board which has the batteries alrady on it. it just needs to be dropped in place inside the shaver.
you will find this part at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
Jan 15, 2010 | Braun Flex Integral 6525 Electric Shaver
My Norelco electric shaver #1378/E does not work any more after years of good service. The green charging light is on when plugged in and it flashes when the machine is plugged-in for a time. I...
When your shavers batteries get old enough, they will internally short out or severely corrode. If they internally short out, you will not be able to run the shaver even on the cord. If the batteries are severely corroded, the corrosion may interfere with the switch or wiring causing it not to work. To get it running, you will need to change the batteries and maybe do some work with the wiring and/or switch.
Batteries can be purchased at shaveroutlet.com. They also do repairs if you need it
ShaverOutlet com The Ultimate Shaver Source
Mar 27, 2017 | Norelco Reflex Shaver 5885XL Electric...
My braun Flex 6520 does not turn on. When the cord is plugged in no red or green lights come on. Is this a costly repair? Would it be better to buy new as this razor is approximatley 5-6 years old?
The cost to repair this isn't going to be nearly as much as a new Braun shaver as nice as this one.
The problem is that your rechargeable batteries have become degraded to the point that they won't take and hold a charge. Because the batteries have become so degraded, that even with the power cord plugged into an outlet, you still can't use the razor solely on AC power either.
If you want to have the shaver repaired for you, you can contact www.electricshaver.com or give them a call at 1-888-476-1785 to get an estimate of the repair costs. Typically it takes about a week or less once they receive your shaver. They also stock most parts for many brands of shavers, including your Braun. I've used them for getting parts for several of my shavers and found them to be a very good company.
If you're handy and have a soldering iron you can disassemble the shaver and remove (unsolder) the bad batteries and solder in a new set. There are two small caps on the bottom of the razor that cover the screws that hold the body havlves together. Remove these with a small pick or small flat bladed screwdriver and remove the screws and carefully remove the body halves and that will let you get to the main board and the batteries.
Simply heat up your soldering iron and melt the end tabs off the batteries and remove them. Then solder in the new ones and make sure they are properly secured and have adequate solder on the tabs for a good connection. Put the covers back on and install the screws and and the caps and your all set for recharging the shaver. Let it charge for at least 8 hours and you should be all set!
So whether you decide to have the repair done for you, or do it yourself, I hope you find this Very Helpful and best regards!
Oct 08, 2009 | Braun Flex Integral 6520 Electric Shaver
I have a braun 360 razor. I yr old,seldom used, and it wont turn on.. I takes a charge and when i plug it directly in to the outlet it still wont turn on..
Your battery has degraded to the point that it won't hold a charge and also won't pass voltage/current and thus doesn't work even when plugged into the outlet.
You need to replace the rechargeable batteries to get your razor working again. If you want to do this yourself, check my other posts on how to access the internal circuit board and unsoldering the faulty battery and replacing it with a new one.
You can also contact Electric Shaver Service at 1-888-476-1785 to get an estimate for them to do the repair for you. They are reliable and quick with repairs usually done within a week from reciept.
Hope you find this Very Helpful and best regards!
Jul 16, 2009 | Braun 360° Complete Electric Shaver
Motor does not start.
electric shaver hq5812 charges,light is on but does not cut efficiently
Aug 25, 2007 | Philips Philishave HQ5812 Electric Shaver
Braun 4501 Electric Shaver Logo
229 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
