Hi My TV is making a buzzing sound and at times then the picture goes? what should I do. I turn it on and off, checked all cables - all seems fine
  • 8,457 Answers
The standard CRT tube tv have a FBT-it call the Flyback Transformer.It a big black block of plastic with a red wire with a black cap hook to the CRT tube.Have tools like a soldering iron and solders?Know basic soldering?Resolder the FBT,should solved this problems,not than the FBT,must be replaceed.These days CRT Tube Tvs parts are hard find.Good luck,fixing this tv.
Posted on Sep 08, 2010
Buzzing sound + Tv picture is very weird.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS.. AND ALSO ALL FUSES AROUND IT .THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE.
GOOD LUCK
May 23, 2010 | Polaroid TLA-01911C TV
PS3 HDMI Problem
it seems like the connectors on the HDMI cable is screwed or maybe a small connection issue within the console try a new cable is un helpful may need to check the connection on the machine or TV
May 29, 2009 | Sony Playstation 3 (PS3) Console
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Astar LTV-32ASB turns on then picture goes out & sound remains on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Mar 08, 2009 | Astar LTV-32ASB 32 in. LCD Television
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Koss KLD2700 LCD TV no picture
http://www.fixya.com/support/t860220-screen_blank
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
Jul 31, 2008 | Televison & Video
Television sound
if you have a converter box hooked up to the tv as well turn the volume down on both devices and bring the volume on the tv up to mid range, then increase the volume on the converter.....one is overriding the other
Mar 27, 2006 | RCA F27628 27" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
