Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Jandy Aqualink RS Main panel randomly goes into service mode turning off pump and heater and locking out controls. button in main panel can be pushed to put back into auto or time out mode but it just goes again on its own into service mode. any ideas?
    Top Expert:
  • Jandy Master
  • 5,706 Answers
Bad bezel board
Posted on Mar 05, 2016
5 Suggested Answers
  • 128 Answers
SOURCE: Jandy Aqualink RS
Disconnect the spa side remote.
Posted on Aug 23, 2009
  • 128 Answers
SOURCE: We have the Jandy AquaLink RS PDA, we have two
If you have a spa side remote unplug it at the outside control panel. If the problem stops it's the remote
Posted on Aug 30, 2009
  • 246 Answers
SOURCE: Jandy aqualink RS handheld went out during
GO TO THE MAIN PANEL AND RESET THE SYSTEM
Posted on Oct 13, 2009
  • 246 Answers
SOURCE: My Aqualink RS Wireless says Pool Heater Jandy
AT THE HEATER PRESS THE BOTTOM TO TURN THE HEATER ON LINE IF NOTHING HAPPEND THE HEATER MUST DE WIRE CHECK YOU MANUAL FOR THIS ONE
Posted on Oct 15, 2009
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Power to control panel is off and pump continues to run ?
you need a new 3 hp relay trace wires from filter button red and black wire go to the relay
Apr 12, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have an Aqualink RS that will not turn the pool's filter pump on either by remote or in service mode
check your jandy valves make sure they are fully open or closed they can lock your system if they are not in full closed or open mode second option is to try to turn jandy valves manually to if they are in spa mode manaully change then to pool mode or if they are in pool mode change them to spa manually on the jandy valve there is a 3 way switch this is where you can turn them manually wt we want is to send the signal back to the main control outside that the valves are in ready mode look in the main control open the door and see if there is a red light that indicates another problem if you can send me where the red light is what the red light label says it will help if you send me the aqualink model #
Oct 06, 2013 | Standard Power Center for Aqualink Rs
We had an intense thunder storm and lightening the other night. My indoor Aqualink RS8 has a blank screen and is unresponsive. It apparently is not getting any power. The Spalink controller is blinking...
The circuit internally have gone short.There are many other facing this same problem.Some have got this indoor panel dead due to moisture collected on the indoor panels circuit board.The panel is not very strong to handle the humidity effect.It gets short. It has to be replaced. To get any other part and also the indoor panel board please click on the link below http://poolparts2u.com/products.asp?catid=0&scatid=27 ------ Thanks.
Jul 19, 2010 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Jandy Aqualink RS
Jul 11, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Jandy aqua link main control box
Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
Repalce the button or disconnect it at the outdoor panel.
Oct 28, 2008 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
164 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
