Question about Frigidaire ATF6000ES Front Load Washer
Washer won't start, lights all work except top one, door lock. I changed the locking device but still the same. On the trouble list the next step should be to change the control board??? The model is Frigidare FTF2140ESO front loader.Is this my next step???
    President:
  • 1,430 Answers
The board would be the likely problem if the switch is good. To double check the switch check it for ohms, it should be around 1500 ohms no lower than 1400 if it is the switch is bad if it checks good replace the main control. Here is a link that should help http://appliancehelponline.com/washercontrolboard.html
Posted on Sep 08, 2010
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
Tip
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
on Aug 02, 2010 | Samsung DVD-P241 DVD Player
Not working
Good Afternoon James,
I see that you are still having trouble with your Frigidaire Affinity washer, model# ATF7000E, finishing and now starting a load, even after replacing the door lock.
I would start by making sure that your washer door is completely closed.
Next I would check to make sure that your washer controls are not locked. You will see a "LOC" code if the controls are locked. To get them out of the lock mode, press and hold the "Options" and "Select" buttons at the same time for 10 seconds.
If you are still having trouble you will want to give your washer a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
Once power is restored, if you are still having trouble with your appliance either not starting or not completing the cycle, I would recommend contacting either the manufacturer or your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
What caN I POSSIBLY DO NEXT? 6 KIDS NO WASHER, AND SERVICE WARRANTY SUCKS!
Problem closing the door
Door lock faulty
Wiring faulty
Main board faulty
Cycle is paused Start
Apr 28, 2012 | Electrolux EIFLW55HMB Front-Load Washer...
My maytag MLE2000AYW will not lock, how hard is it to replace or fix?
I would be concerned about your door latch wax motor ( part # 12002535) though... See Neptune Help for more information about replacing the faulty wax motor with brown colored actuator tip before it damages your machine control board.
When the wax motor shorts out it will blow the Q6 triac and then the R11 resistor will burn and your door probably won't lock anymore as indicated by the door locked light not coming on. The next thing you will notice is that your clothes will be soaking wet after the wash cycle because the spin cycle will not work if the door does not lock...
Your machine control board is located above the dryer on the right side.
Every Maytag Neptune front loader with a timer knob (non digital) has a wax motor and all of them shipped with faulty one except the later 2000 series stacker models. You should proactively replace the wax motor with the new design (with black tip) to prevent the Q6 R11 failure on the control board. If you're too late you can try the STAGE 1 repair kit at the same site above.
To inspect your door latch wax motor on the stackers you:
  • Unplug machine
  • Remove the (2) screws holding center panel and remove panel
  • Remove the (1) center screw holding the top panel located inside compartment above washer
  • Remove the top panel to expose the door latch assembly
    I hope this helps you.
Mar 27, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
The locked light stays on but the top load door is not locked, and the washer will not start. I have unplugged the washer but still the cycle will not start.
What is your model type a FAV6800A or FAV9800A?
Are you up to troubleshooting the issue? We would need to see if the Left or Right hand lid lock is signaling the Control Board incorrectly. This could involve using a DVM to measure +12 VDC signaling from the Lid Locks to the Control Board.
A power Cycle of the Control Board won
Feb 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
327 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
