Question about Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP)
I have a 5 burner charmglow grill, lately if i try to light more than 2 burners the flame will die down to almost nothing. please help me
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 08, 2010
I have a four burner CharmGlow BBQ. The two burners closest to the tank have high flames, while the two furthest from the tank have very low flames and will blow out if it is windy. I have replaced the...
Since you have done every other thing I would have suggested, try this .....
Turn the tank valve OFF and disconnect the hose from the tank. Wait 10 minutes and reconnect the hose to the tank. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow) until it's fully open. Now, the light the burner farthest from the tank first and turn it to HIGH. Did the burner light and does the flame height look correct? If co, light the remaining burners the exact same way, starting with the one next to the one you first lit. Now, did all the burners light and do all the flame heights look correct? If so, you solved the problem. The problem was with the regulator, which was partially closed.
If the above didn't solve the problem, check the burner orifices of the two offending burners for clogs.
Hope this helped you to further troubleshoot & solve the problem. Happy Grilling and thanks for choosing FixYa.
Sep 19, 2011 | Grilling
How can i manually ignite the grill
What I do is remove the grates and flame guards and light the burners with a stick lighter then turn em on low and cover them with the flame guards then sit the grates back on there.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 28, 2011 | Brinkmann Charmglow Stainless Steel LP...
The burners do not get a full flame anyomre, nor
you may have spider web in the burner ... disassemble and blow it out with canned air or a air compressor ...
May 02, 2010 | Brinkmann Charmglow 810-7400-S Propane...
I can not get any gas pressure in main burners or side burner, i have a new propane tank, just a trickle of gas not even enough to keep side burner going when only using side burner, will only produce a...
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
Jan 24, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Charmglow burners lite but only have small flame when set on high
replace fuel regulator-low pressure...these hang up in the off season
Jul 24, 2009 | Home Decorators Collection Charmglow...
Front of burner will not light
It sounds like it has grease or dirt in it. clean it carefully and try it again.
May 22, 2009 | Brinkmann Charmglow 810-7400-S Propane...
As you light additional burners, flame dies down to almost nothing
did this problem just start? if so check your regulator or the main line for a crimp or obstruction.
May 16, 2009 | Grilling
New grill (Charmglow 810) unusual (to me) line of flame
The line of flames you describe is the cross over between the burners. You can light one burner and the rest will light from the coss over flames.
Nov 25, 2008 | Brinkmann Charmglow 810-7400-S Propane...
Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP) Logo
314 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
