Question about BenQ MP510 DLP Projector
Benq mp512 shuts down after only 20-30 seconds of use. the lamp has 1200 hours of use. what could it be?
SOURCE: PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Posted on Nov 18, 2008
SOURCE: Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Posted on Feb 11, 2009
jyackle5
  • 8197 Answers
SOURCE: Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Posted on Mar 12, 2009
SOURCE: Benq PB8220 lamp used for 375 hrs shuts projector automatically
Unplug any cables from the projector (except for power)
On the device (not the remote control) hold down exit for 3 sec
lamp status are shown
on the remote control use MENU, and then left right to reset lamp
Posted on Oct 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Posted on Dec 13, 2009
My benq MP 512 shuts down after a few minutes of use. when it shuts down all 3 light indicators are off, fan also goes off.
DONT WORRY THIS IS A REGULAR PROBLAM OF BENQ ,DELL,INFOCUS PROJECTORS UR MAIN POWER SENDER IC IS DAMEGED THROUGH UR PROJECTOR AND BUY EPSON,HITACHI,SANYO PROJECTORS
Mar 12, 2012 | BenQ MP512 SVGA 2200 ANSI 25001 22KG...
Where can we buy in the Philippines a replacement lamp for a BENQ MP512 projector?
Try buying it off the Internet, Google a replacement lamp for your model data projector. You can then get a price comparison from the various suppliers.
Sep 01, 2011 | Office Equipment & Supplies
Start power on, a few minutes the lamp shutdown, tempreture and lamp signal alert.
Possible that the filter is clogged on the ventilation fan and must be cleaned and reset.
So remove the filter and clean , check for dirt or obstruction. Check the free flow of the fan to the lamp, if the fan is faulty or not running to the desired speed to cool.
Restart and allow the lamp to be cooled externally to confirm.
Apr 06, 2011 | BenQ MP512 SVGA 2200 ANSI 25001 22KG...
Hi, I am looking BenQ MP512 ST lenses replacemente. ¿Do you have any idea about where can i find them?
Dear Sir,
this is Jacky,
a professional spare parts supplier for projector in China,
our company have the lens for Benq mp512 ST, original.
USD160/pc, from China to your door, including the freight, by TNT express,
if you have any question, please feel free to contact me by tel or email
Jacky
0086-532-80661377
E-mail: wanmingjun@gmail.com
Nov 22, 2010 | BenQ (200NSH-LAMP) Projector Lamp for...
Dec 12, 2009 | BenQ PB8220 Multimedia Projector
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
My Benq PB6100 shut off after a few seconds
I had the same problem.
First thing to do is look up the owners manual, unless you happen to still have it, then verify the the sensor for the second (or rear something that sounds not like first) temp sensor is going off. If it is basically the fan that sends air into the lamps compartment may be clogged. I have had mine for several years and recently had the same problem. I almost went out to buy something new until I convinced myself that there was no harm in taking it apart and trying something. Good thing too, since all I had to do was clean the fan and reassemble. After that it stopped turning off by itself and I haven't seen any red lights.
Good luck to You!
Mar 19, 2009 | BenQ PB6100 Multimedia Projector
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
Lamp goes out after about 20 minutes of operation, does come back on after pressing the power button again, but not for long.
how old is the lamp? If old then at end of life and projector shuts down automatically to avoid damage. If new bulb reset lamp in OSD menu
Dec 27, 2007 | BenQ PB6110 Multimedia Projector
BenQ MP510 DLP Projector Logo
77 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
