Question about Nokia N900 Smartphone
My n 900 have only 5 hours battery back up and loose full battery charge without using mobile
    Sergeant:
  • 172 Answers
If you have any email messaging service on this phone that needs to connect to the server to check emails even without using it it will try to sync to the server to get an email and its eating up the battery charge.
theres a settings to check the email every 5 mins or so, you can set it to manually sync your email so it wont eat up your battery life.
Its also applicable if the wifi is on because it will try to search for a wireless network.
hope this help.
If ever non of this is enable with your device, no email messaging or wifi is off. then use a known good battery. the battery pack that came with your device is defective
Posted on Sep 08, 2010
I charge the battery and mark it's full charge,but on the scooter the indicator don't mark is full charge and when you drive,the speed just suddenly will drop and come back ok.
Charging batteries to full means leave on charge for 12 -16 hours as it may show charged but the charger goes into what is called a battery conditioning mode where a small trickle charge takes place to fully charge batteries. Again, how old are batteries and have you had them load tested at all?
Jun 15, 2015 | Drive Medical Health & Beauty
Acer Aspire 4830T battery issue - Laptop shutting down abruptly though the battery shows 90% charge available.
Did you follow the initial charging instructions that came with the battery from the manufacturer? Does the battery fit properly and is not loose or gets loose during use/moving around? Are the cooling fans under the unit all clean, clear, unobstructed and working properly? Is the battery of the same type as the original? You can't always replace a Cadmium with NImh etc, the charger may not be compatible and give you erroneous indications and poor charging performance and may damage the battery.
Oct 24, 2014 | Acer Aspire Timeline X 4830T 14 Inch...
How long should I charge my 900mah li-ion batteries for the first time? How long should be after first time?
You should be OK to charge the battery for 10 hours at a constant current of about 90mA. I assume this battery is a 3.7v type, with a full charge voltage of about 4.2v (it would be useful to monitor this with a multimeter).
Some useful commentary is here: https://www.sparkfun.com/products/341
Good Luck
Jun 08, 2014 | Sony AA Nimh 2500 Mah Rechargeable Battery
Power drain from batteries when i have charged the batteries to full within 2 hours the power has drained to needing a charge again without using the scooter i have replaced the batteries for new ones...
You don't sound like a mechanic or electrician and I doubt you have the meters necessary to troubleshoot this problem so I'd recommend you take in for service.
If you replace the battery and the problem continues it is probably the charging circuit, but there is no guarantee, it could be that one of your new batteries is not good and if you mix good and bad batteries, and run them down, the bad cell will cause a voltage refersal that will ruin the battery.
Sep 02, 2013 | Electric Mobility Health & Beauty
HI Scooter is on charge full time and used daily after 30min i loose the first green light that is OK but if i dont use it for one or two days i loose the first green light only after 10min can you...
well it could be that you overcharged the batteries. You should not leave the scooter on the charger full time. you should charge the scooter nightly while you sleep unplug from the charger when you get up in the morning. the charger should not be on the scooter more than 12 hours per day and that rare. Whenever you have a red and green light on the charger the scooter is fully charged and can be unplugged. Always put it up fully charged and then charge after each use. Your batteries need to be replaced and charge the new ones before use then charge overnight each day that you use the scooter. If you don't use it for a few days you should still be fully charged than charge after use Hope this helps
May 12, 2011 | Invacare Supply Group Invacare Scooter...
Hi, I have buy nokia 5300 battery BL-5B on last week .but this battery have not standby long time ..I have charge battery morning and mobile have full charge battery 1 hour .then I call to mobile 1...
if you know how to use a multi tester try to check if your phone is shorted, put the range value to ohms x1 and top it to the positive and negative battery connection of the phone.
Oct 11, 2010 | Nokia 5300 Grey Cellular Phone
We purchased a Rascal 300 two months ago that worked just fine. We seen proof that new batteries had just been purchased. It has a built in charger and we have kept the batteries charged. The charger now...
Here's a link for the owners manual for the 300 model. Click on it and it will open as a PDF document that you can print. http://www.rascalscooters.com/manuals/300_manual.pdf
The ammeter back in the trunk should be registering when you plug the scooter in. If it isn't, this doesn't mean that it isn't charging as the meter itself may be bad. Put it on charge for a few hours and see if the "fuel guage" on the top of the tiller comes up to full. If it does, than your charger is okay and you just need to ignore the ammeter not working until it doesn't charge at all anymore, then the charger is bad. Note too, that later on when the batteries get weak and you can only go a little ways, that it still means your charger is okay, batteries not. Even bad batteries well show a full charge, but they won't take you far at all. If the batteries don't show a full charge after a few hours, then you need to replace the onboard charger.
Good luck
Jul 10, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Charging
i would say it all depends on how many AH your battery is and what amp your charger is they differ between 8 to 14 hours that is for new batteries as a battery gets older the less time it takes to charge so if your batteries are getting fully charged in 2 hours its time to start thinking of changing them
good luck and hope this helps
clive
Jan 17, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Battery Charge - First Use
My experience was similar to yours. The LED turned green after about only 2 hours. Because I didn't want to stay up until midnight to start playing with my Axim, I took it out of the cradle after the 2 hours and everything was fine. Besides, having downloaded and read the user's guide 2 days before receving my Axim, I knew that a green LED meant it was ready to go. 3 days later, everything is still fine and seems normal. A year ago, I received a Palm with similar initial charging requirements, and it also didn't take as long as the directions said it would.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Nokia N900  Smartphone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
