Question about Haier HL22R 22 in. LCD TV
Remote control will not turn TV on or off, have installed new batteries, Remote is for the LCD/TV/DVD. TV will operate with control panel function
    President:
  • Haier Master
  • 1,779 Answers
Take the remote to a retailer that sells Haier and see if it works there. If it does, then the IR receiver is bad in the set. If not, then the remote is defective.
Posted on Sep 08, 2010
Trying to match up a triantianyong TV-139F universal tv remote to this LCD TV DVD combo.
Search Results
    Universal Remote Controls - Encompass Parts
    https://www.encompassparts.com/staticlist/Universal_Remote_Controls
    TVs made since 1988. Works Mitsibushi . TVs only. Will not operate. TV/VCR or DVD Combo units. ... fully operate yout TV. Full function replacement remote for ToshibaTVs made since 1988. ... 2004-2005 LCD TV's. ON/OFF, CHANNEL +/-, ...
    Universal TV Remote ' eBay
    www.ebay.com/bhp/universal-tv-remote
    eBayUniversal Remote Controller 6 IN 1 TV DVD VCR Satellite Receiver Cable Box Audio... control for Samsung LED/LCD TV is the lastest product, easy to operate and ...damaged or needs to be substituted, or when you dxxire to have a combi.
    Codes For Universal Remotes ' Universal Remote Control ...
    codesforuniversalremotes.com/
Feb 05, 2016 | Universal Televison & Video
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Wont change input
sounds like the volume up button is stuck on the tv , try fiddeling with it on and off , because it is locked down the other controls will not function
Feb 07, 2012 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
Just did. Where did it go? Remote control does
Not the remote,it is the tv itself.Now,turn on the tv it have a flashes of pictures only a few sec. than dies and have sound left only?Yes,than the tv have a 1 or 2 long board call the LCD inverter boards,they are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 refurbishes long LCD inverter boards for the replacement.
Dec 10, 2010 | Toshiba 32HLX95 32 in. LCD TV/DVD Combo
Remote control stopped working. no signal
I apologize if I am stating the obvious. Replace the batteries with NEW ones and be sure they are installed with the correct polarity. Also, assuming this is a multi function remote, press the TV function button on the remote. Often a remote gets inadvertently set for dvd, or tuner control and then will not control the TV. My Samsung remote for example can control a stereo, vcr, cable box, and dvd plater in addition to the TV. If none of these simple fixes solve the problem you will most likely need to replace the remote. Try partstore.com
Nov 16, 2009 | Vivitek V37835 46 in. LCD Television
Emprex HD 3202 control panel not operating
My first thought then is that the main board may have capacitor damage that will affect the boards ability to "understand" the control signals, if you can I would have the tv looked at at a service center for damaged boards and components, might be an easy fix but might not be (new boards), The lcd panel is good that can net you several hundred dollars at a min.
peope break them all the time and a simple change out is worth several hundred dollars, vs a new tv
Apr 09, 2009 | Televison & Video
REMOTE OPERATION
Looks like a common frequency and coding problem. Try to keep the TV and Cable box far away and try the remote. If it works, then, escalate to Cable operator for providing a new box with remote or ask for a different brand of cable box.
Jun 10, 2008 | Protron PLTV-37 37 in. LCD Television
Remote control
If your remote is for the TV you may have to program it to the DVD or vice versa. Not all remotes will work with two different products un less it is a universal remote. Then if the DVD or TV is made in China the may not have codes that will work. Only original remotes will function
May 14, 2008 | Insignia 37" LCD Flat-Panel HDTV
Can't control DVD functions from remote
absolutely ridiculous. i ran into this problem too.
Mar 01, 2008 | RCA L26WD26D 26 in. LCD TV
Haier HL22R 22 in. LCD TV Logo
61 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
