Question about Frigidaire Refrigerators
My frigidaire model # FRS6LF7J type 7 runs but it don't get cold in both side. after reviweing it, i found that the fan inside the frizer is not working, its new frigidaire and had it home for 9 weeks.
  • 4,059 Answers
Well, that fan must run to cool properly but that might not be the only problem, The fan is probably controlled by the control board in yours since it's a new one. The fan behind it and in the freezer should run when the compressor is running.
Posted on Sep 08, 2010
Testimonial: "thanks but i know that i just need to find out where i can check at and what to do. thanks"
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
What stop the compressor, water spilled on the freezer fan though the vent by the ice maker. help
Most likely the=> 5303918476 Defrost Control Board will need to be replaced. This board can be found inside the control panel inside the fresh food compartment. Unplug power and lets examine the board. Here is another source for the board 5303918476 Defrost Control Board Here is a photo of the inside of the control panel HERE and item location 23 is that board. I am here should you have questions, Sea Breeze
Soemtimes the defrost control board will show signs of failure with burn marks and heat damage but not always. It is likely this board is the problem and in some cases the start relay and run capacitor can cause these same symptons.
Jul 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
Refridgerator side is not cooling and freezer is wroking fine
1st i must get you to look for some symptoms look on back wall (inside) of freezer. Is there "sno-cone" type frost? yes? defrost problem. heater,defrost thermostat or defrost timer or adaptive defrost control. no? is fan running? is evaporator coil cold ,frosty? no fan but cold frosty coil(that's frosty but not frosted up) then bad fan motor probably. you need volt meter,and know how to use it. otherwise call a tek.
Sep 25, 2012 | Frigidaire FRS3R5EMB Side by Side...
MY FRIDGE THE FRIZER WORK GREAT,BUT THE FRIDGE BOTTOM NOT
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 22, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore refrigerator model # 596.75522400 bottom frizer. Frizer works ok but refrigeratot does no get cold.
If the freezer is cold, it is probably the evaporator fan motor or the damper. The damper is the easiest to check.
Inside the refrigerator compartment, top, center, back is a small plastic grill that snaps out of a larger plastic housing. Tug gently from the bottom edge. You should see a small damper door. If it is closed, push it open. If you feel a flow of air, the fan motor is good and the problem probably has something to do with the damper not opening. If you do not feel the flow of air, it is probably the evaporator fan motor.
If it is likely the damper, you can prop it open to get the refrigerator compartment cold again until you can solve the damper problem. I have not had to solve this problem yet, so good luck.
I've had problems with evaporator motors in every Kenmore appliance I've owned. So, it is probably the evaporator fan motor. The motor is just above the evaporator coils inside the freezer compartment.
Lift out the baskets and lift off the drawer front. Remove the drawer slide mechanism buy depressing a single plastic clip on each side as you pull the slide forward.
If you
Oct 23, 2010 | Refrigerators
TOP FRIZER WORKS BUT REFRIGERATER SECTION DOES NOT WORK
This sounds like either a defrost problem or a evaporator fan problem. Listen for the fan in the freezer to see if it is operating. If it is a defrost problem the back of the freezer will usually be covered with frost. What is the model number of the fridge and i can help you further.
Jun 05, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
The frizer outside is very hot. kenmore model 71192107 year7/02
The condensor coils run around , up , down , the sides of the freezer . This heat is the heat being pulled OUT of the inside , which makes the freezer cold . Freon (refrigerant) attracts heat , which causes the frost in refrigeration . But , the heat has to dissapate , otherwise , hot gas would pump thru the system , and , no cool . A freezer does not get cold , Heat is pulled out , causing food to freeze . So , hot is good .
Aug 01, 2009 | Refrigerators
Frigidair side by side refigerator fan not operating
I do see the power to the evaporator fan section going through the adaptive defrost part number 240554502 It would not hurt to unplug for a few moments and open the control panel inside the fresh food section and examine that control board. With it doing that you may see signs of heat or burn marks on the ADC Let me know, Sea Breeze
Jul 21, 2009 | Frigidaire Refrigerators
Fridge / Freezer no longer cooling F26R4ARS
it could just be the start switch on the side of the compressor. the only way to test that is to replace it. <$20
Jun 29, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side
booster on compressor not condesor, if you needed a "boost" to run compressor sounds like you got bad compressor.
Feb 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
212 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
