Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
After selecting cycle and pushing START, the START LAMP flashes on and off, but the machine does not begin to operate.
  • Whirlpool Master
  • 3,247 Answers
It is likely the door switch is not working.
Confirm the door is shut and you are able to latch properly.
If still a problem then door switch needs to be fixed.
Please provide a Model no. for you dishwasher. Could be something like GU2...
Posted on Sep 08, 2010
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Machine wont fill with water.i have checked pipes and they are okay.if you turn program knob to the spin cycle it will try to enpty.also you can still open the door
Hi there....looking at the programe selector knob....you should see at three positions on the panel a black dot.....ok.......(1) close the door of the machine and switch on the power....(2) turn the programe knob to any one of the dot positions....(2) push the start button....a red indicator lamp should flash 3times and then remain steady indicating the program has been cancelled....(3) Now select a new wash program and push the start button....machine should operate ok....If not check the drain pump to ensure it is not blocked...or wiring loose ...or burned out....if this is ok...then your most likley looking at a module failure...
regards Sir Galahad
Sep 03, 2009 | Indesit W 123 Front Load Washer
Lights on Washer Machine flash but Washer doesn't work
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 31, 2009 | Kenmore Washing Machines
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Start flashes and will not begin wash cycle
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Jul 01, 2006 | Kenmore 24 in. 16293 Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
47 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
