Question about HP Deskjet 3845 InkJet Printer
Printer indicates "paper jam" when there is none.
  • HP Master
  • 6,993 Answers
disconnect the printer from your computer, uninstall the printer software/program from your computer's control panel, restart your computer, reinstall the printer software and try again. If that still does not solve the problem, then you will have to follow a plan B option.
You will have to download Hp diagnostic utility on your your computer,install is on your computer and it will help to detect and solve the problem.
Visit the hp link below, read all the information on the page and download the diagnostic tool from the page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02114788&tmp_task=solveCategory&lc=en&dlc=&cc=us&product=441125
Take care.
Posted on Sep 08, 2010
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Cheers!
-a.
Apr 10, 2012 | HP LaserJet P2015dn Printer
Message reads:-Paper is jammed in the product. Turn off the product, open the scanner unit, and remove the paper. See documentation.' I have checked for any paper jammed, but finds none. I have even u
Did you try unplugging the power cord and waiting a couple of minutes, then plug back in and see if the printer resets itself. Also try checking all the paths that the paper travels through the machine for any scraps of paper that may have torn off during the jam up. Sometimes a very small scrap will prevent printers from resetting themselves. Also disconnect the printer from the computer before unplugging so the printer doesn't receive any signal from the computer. It may not mean anything.
Dec 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Paper jam indicator shows after jam is removed
power cycle the printer, meaning pls. turn off the printer, then wait for about 10mins. turn it back on. while it is off check for obstruction or paper jam inside the printer, if none, turn it back on
if the issue persist, that means the printer is already broken
Feb 12, 2010 | Epson RX620 All-In-One InkJet Photo...
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Kyocera 3900dn says paper jam in rear but no jam evident
Usually a printer doesn't lie when it indicates a paper jam, if you have checked as thoroughly as possible and no paper can be found. It is possible that the paper just isn't feeding and a printer will sometimes indicate a paper jam when paper doesn't feed. But if this isn't the case and a jam is indicated as soon as you turn the printer on, one of the plastic jam sensing actuators may be broken or hung up.
Aug 05, 2009 | Kyocera FS-3900DN Laser Printer
Artisan800- printer says paper jam but none exist??????
Presence to indication about jam paper is defined sensor. Much often быват so that after extraction of the stuck paper sensor or remains in lifted position, its holds up or he conks or falls out of full tilts. Check all sensors, recall, when this has proceed from what node took out the sheet, most often paper sticks on output and more often there conk the sensors. The Other way no. Good luck
Jun 17, 2009 | Office Equipment & Supplies
Printer says paper jam but there is none
Look Inside of each cover on the printer & see if there is a small piece of paper inside. Also, check if there is loose dust from the paper built up by the sensor switches. If none of these work, try flipping the sensor switches manually. Sometimes these get stuck in a particular bad paper jam.
Feb 11, 2009 | Canon Pixma MP500 All-In-One InkJet...
Printer indicates paper jam. Cannot find any evidence of papejam.
if you as service man you can unerstand my solution
follow up
1.your printer lamp thermostate or thermostater is cuttoff or printer cartridge is not properly instald. it is a technical problem
Feb 05, 2009 | Samsung ML 1610 Laser Printer
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
HP Deskjet 3845 InkJet Printer Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
