Question about Sharp AL-1641CS All-In-One Laser Printer
Not printing The cylinder is flashing, I've taken it out, cleaned it, changed toner, everything. When I close it, it revs up as if it will start then shuts down again, with the same symbol blinking. Is this a part that needs to be replaced or something?
  • 3 Answers
It could possibly be your drum or PCU assembly needs replaced. If you have your owners/users manual, it should give a definition as to what the symbol is.
Posted on Jun 27, 2008
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
One cylinder fires intermittently
Run a cylinder leak down test
Mar 04, 2017 | Yamaha Motorcycles
We have a Xerox Phaser 6350 and I was printing some copies today, when I looked over and it stopped printing magenta. So, I replaced the toner cartridge and opened the printer to make sure that everything...
Make sure you turn the printer off and back on a couple times. The fuser is not "hot-swappable"meaning you need to cycle the power for the machine to recognize it. If after doing this and you are confident that the fuser is seated correctly the next step would be to replace the fuser (part# - 115R00035). ItemInc.com has these in stock and ships same day. Hope this helps and thanks for using FixYa!
Aug 02, 2011 | Xerox Phaser 6350/YDT Laser Printer
My Brother HL 4040cn printer is leaking toner, black and yellow. It leaves spatter spots of these colors on printed pages. The machine does not have any messages. Do you know what this may be from or how...
If you've taken the printer apart and cleaned the belt unit and everywhere else in the paper's path, then it is probably either a bad toner cartridge or the drum. Since it's multiple colors producing splatter, its most likely the drum unit. Try taking the drum out and removing all of the toner cartridges and then clean the drums and corona wires. If its still producing splatter afterward, you've got yourself a bad drum.
Jul 20, 2011 | Office Equipment & Supplies
Hello, I have a Brother printer HL-5140 Laser--I know it is an old one--just like me!! I know this printer and would like to continue using it. It had paper stuck in it and I pulled it out. Now it won't...
If toner and drum lights are flashing when there is no real problem, you can reset them. Turn printer on, then with front door open hold down both buttons leds will light one at a time and after status lights release buttons and close door.
Or, if paper jammed light is flashing... try this link:
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/002600/000015/faq002615_000.html?reg=eu&c=gb&lang=en&prod=hl5250dn_all&Cat=11
Jun 29, 2010 | Brother Office Equipment & Supplies
Printing 1 1/2" down right side of paper
You have a defective toner cartridge, drum should be clean when you looked at it, the blade is failing. Is the cartridge remanufactured (or compatible)? Although they usually work well (depending on the supplier) there are sometimes defects
Nov 25, 2008 | Canon PC-980 Color Copier
Dell printer 1700
First unplug power cord and plug back after 10 mins.
If problem persists, then it is probably a toner error, if the toner is nearly finished. In this case you will see the led flashing only when is printing. Sooner or later the printer will start printing blank or faded pages and you will need to change toner
When is not toner, with same symptoms as above, it can be drum error, in this case printer will keep printing but shows flashing light, at a certain point you will need to change drum kit.
If light flashes and printer does not print, then it is either paper jam inside, or one of errors above at final stage, or one of the door not well closed (check them all), or printer faulty (fuser, heads mechanics etc.), in this last case call service.
Mar 21, 2008 | Dell 1700n Laser Printer
Brother all in one printer
Do you run a laser printer (you ve mentioned toner). If yes. plz post under your printer (e.g. HL-2040 etc.).
This is the ink jet forum!
Jan 10, 2008 | Brother Multi-Function Center MFC-240C...
Sharp AL-1641CS All-In-One Laser Printer Logo
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
