Question about Microwave Ovens
So I reheated a dish for 40sec. I take it out close the door look at the time and there is nothing. checked the breaker down stairs it was on. It is a panasonic the genius prestige 2006. is there a fuse?
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 08, 2010
No power to thee microwave. There is power to the breaker
There is a door safety switch - check to make sure that it is closing when you close the door. If it is check the fuse and see if the magnetron is getting power. If it is and nothing happens the tube is bogus.
Aug 25, 2017 | Microwave Ovens
Why does our new microwave not work? Can set the time and it counts down when we have pressed start but does nothing else.
There is a big fuse inside that thing. Check to see that it is not open. Could be that the magnetron, lite, and dish are all on the same circuit.
Sep 21, 2015 | Daewoo KOR6N9RR Microwave Oven
How do I reheat frozen lasagna
Microwave ovens are not meant to cook food, except in a very few situations. If the lasagne has already been cooked before it was frozen, then you'll need to weigh and to reheat it in accordance with the manufacturer's instructions in order to ensure the dish is heated through, though it's better to use a food thermometer.
The temperature you should aim for throughout the dish is 83C. Only at that temperature can you be sure that any bacteria in the dish will have been severely depleted.
Feb 21, 2015 | Microwave Ovens
Replacing relay switch in electrolux high speed microwave oven
Sometimes a door latch or magnet closure is a problem. If the door fails to make proper contact when closed, the oven will not start. If the oven goes on and off, there is a disconnect and in some cases the rotating glass dish inside vibrates and causes a disconnect also.
Dec 18, 2013 | Electrolux ICON Microwave Combination Oven
Gh9115xe went off completely sometime after a cup of coffee was reheated. Now, nothing works. The outlet is live.
probably not
there is a glass fuse under the outer case near the circuit board
if that is blown it is from a short so you may have to take it in for a diagnosis
Apr 28, 2017 | Whirlpool GH9115XEB / Q 850 Watts...
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
Nov 23, 2010 | Neff H5470N0GB Microwave Oven
I own a Advantium 120 Oven. I love my microwave however there are times that I need to stop the turntable in order to reheat or cook something in a casserole dish. How can the turntable be turned off?
I guess my problem cannot be fixed. I was told that my microwave turntable is automatic and cannot be turned off, therefore, if you have a 9 1/2 x 11 dish and need to reheat something it cannot go in the microwave because it does not fit .
Aug 26, 2008 | Microwave Ovens
Sharp microwave runs when door closed
This is usually caused by either a bad door switch, a loose door switch mount, or sometimes a problem on the control panel.
I would suspect the door switch mount has a broken tab allowing the switch to swing down when the door is closed, not allowing it to really be activated.
Also, even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 01, 2008 | Microwave Ovens
Microwave quit working after a few seconds......
check if door is closed tightly those hooks on the door activate switches which close the circuit .if not open cover and check contacts on switches
Mar 07, 2007 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
159 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
