Question about TruTech DV288B3 DVD Player
Looking for a hook up manual for VCR/DVD Player, Model DV220TT8
DVD and VHS don't work
The outputs of your VCR/DVD player should be plugged into the audio and video inputs of your TV.
Mar 09, 2014 | Sony BRAVIA KDL-46W3000 Television
Manual for model dvd750vr/17
Here:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCAQFjAA&url=http%3A%2F%2Fdownload.p4c.philips.com%2Ffiles%2Fd%2Fdvd750vr_99%2Fdvd750vr_99_dfu_eng.pdf&ei=sr5EUMPdD7Gx0AGaqoHADw&usg=AFQjCNFIEd1VfYfBlFqFRcQhwOOSDMsywQ&sig2=7w59cHS3yKK4hinpu3pDDw
Sep 03, 2012 | Philips Magnavox DVD/VCR Dual Player
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
Dvd player is only in black and white...no color
Hi, make sure your av chan say`s av2 and not av2s as this will give b/w playback Jamie
Mar 24, 2009 | Televison & Video
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
DVD & VCR Player Manual
www.funai-corp.com/support look on the side see PDF owners manual. Then look in the middle for DV220TT8. You will see it there. Otherwise you will have to call the hot line and they charge 4 dollars for the remote and 6 dollars for shippings. They have to pay for those to get sent out since they are made in a country(malaysia or something)
Nov 19, 2007 | Televison & Video
TruTech DV288B3 DVD Player Logo
53 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
