Question about Cambridge Audio Azur 340A 2-Channel Amplifier
My amplifier shuts down leaving the LED lights flashing. When doing it the speakers make a distinct "boom" or "bang" I have tried checking the fuses, but they seem fine. What can be the problem?
  • kimbhenrikse Sep 08, 2010
    Thank you! Maybe I should consider buying a new amplifier... :-(
  • 6,993 Answers
your amplifier is having a power problem. The power supply board is defective that's why its shutting down. Its receiving power but it cannot transfer the current to the necessary part of the amplifier because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the amplifier might continue to malfunction.
If you know about electronic repairers, I would suggest that you open the amplifier and read the power board/panel with a meter, detect the bad component and replace it.
If you don't know about electronic repairs, then take the amplifier to the nearest repairman to fix the fault for you.
Good luck.
Posted on Sep 08, 2010
Boom audio, blown fuse
Fill the air with sound from this Boom!™ Audio Boom Bagger Kit. This complete audio kit provides the latest in Harley-Davidson® audio components. When installed, the increased power of the amplifier provides the speakers with a clean signal, and a custom equalization is available to further optimize the performance of the Boom!™ Audio speaker system.
  • 4-Speaker Ultra Boom!™ Bagger Kit
  • Ensure maximum output of your audio system with the recommended High Output Charging System P/N 29900028
  • Dealer Digital Technician software update is required
  • Dealer installation is recommended
  • Kit includes Boom!™ Audio 6.5" fairing speakers, Boom!™ Audio 4-channel fairing-mounted amplifier, amplifier mount and wiring harness
  • Speakers feature two-year warranty
  • Stop by a participating dealer to interact with a unique audio display that lets you simulate how your bike will sound with Boom!™ Audio upgrades. Contact your local dealer for details
From: http://www.harley-davidson.com/store/boom!-audio-boom-bagger-amp---speaker-kit-pa-08-76000411--1
Jun 11, 2012 | Harley Davidson Motorcycles
It has stopped workin and the red light is flashing.Is this a code and if so how do you read it
The red light is a power protection circuit designed to shut the amplifier down due to an overload or wiring problem. If the amp was playing then shut off, my guess is a problem with the speakers or the speaker wiring. Some amplifiers are only stable to a certain load. For example, most car audio speakers are 4 ohms which is the resistance placed upon your amplifier to produce a certain volume of sound. If you bridge two 4 ohm speakers together in parallel, you cut the resistance in half, thus increasing the amount of power (and volume) to your speakers. This also creates more heat and could, in effect, shut your amplifier down. I would find out how the speakers are wired to determine the resistance of the load your amplifier is pushing. Also check the grounding.
May 26, 2011 | MTX X Thunder 300XD Car Amp
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    Protection light keep coming on
    Make sure your head unit is off.
    Reset the amplifier using the manufacturers specified method. Usually this is just power down briefly and then back up. I usually pull the amp fuse and make sure all LED's on the amp go out. Wait 10 seconds, and then put the fuse back in.
    If the LED comes back on when you reconnect power, without the HU being on, you've got a bad amp.
    If the LED does not come back on after reset, then check for short circuits on the speaker leads. Still leaving everything off, from the amp terminals, remove both wires to a specific speaker and check for shorts.
    Mar 21, 2009 | Car Audio & Video
    The red led light on my mertik max-802 is staying on when i hook it up. the fuses are not blown out so wat could be the peoblem
    Could be the ground. Or touching wires. if the speaker being hooked up are pulling the wrong ohmage it could also shut down an amp.
    Dec 03, 2008 | Metrik Amplifiers MAX-1404 Car Audio...
    Gemsound power speaker pxa105
    First,
    Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
    If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
    Mister Phil
    Apr 07, 2008 | NAD C350 2-Channel Amplifier
    Protection light
    Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
    Jan 15, 2008 | Volfenhag ZX-7180 Car Audio Amplifier
    Cutting out intermittent problem
    If the voltage is dropping to 8v, it sounds like there is a problem with either the B+ line or the ground connection. You should also check the voltage across the battery terminals to see if the voltage is dropping at the source.
    The amp may be going into protect mode. Disconnect all speaker wires from the amplifier's terminals. Also disconnect the RCA cables from the amp. Does it still go into protect?
    Insert a 20 amp fuse in the B+ line and try to power it up. If the fuse blows with no speakers connected to it, the amp probably has a blown channel.
    Dec 05, 2007 | JBL GTO75.4 Car Audio Amplifier
    Kenwood 7202 Amp that is blowing fuses
    If your speakers are wired for an impedance below 4 ohms mono or 2 ohms stereo, that would make it shut off. If you have a speaker wire shorted to ground, it would also cause the amp to go into protection.
    If the speakers are not the problem, it may be shutting down because the voltage at the amp is dropping too low.
    Oct 19, 2007 | Kenwood KAC-7202 Car Audio Amplifier
    Problem in ppi pcx-2400
    Check the amplifiers fuses. Some amps have speaker fuses that leave the LED on if blown. Check for continuity on the voice coils of both subs. Check for 12 volts on the remote turn on line from your receiver. If all of the above are good, the amp is probably toast.
    Jul 15, 2007 | PPI PCX-2200 Car Audio Amplifier
    Cambridge Audio Azur 340A 2-Channel Amplifier Logo
    110 people viewed this question
    Top Cambridge Audio Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
